SOURCE: Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
SOURCE: pink and green diagonal lines rollng across the
Have you tried lifting the ground on the TV? That set has a grounded (3-prong) plug and sometimes sccrolling lines can be caused by a ground loop in your power lines.Are the green and purple lines very short, like just a few rows of pixels tall, or multiple inches, like 3 - 8 tall?
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
