Dell Latitude E5520 Laptop Computer PC Notebook Logo
Posted on Mar 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anyone has any issues keeping a connection up using "Intel(R) Centrino(R) Advanced-N 6205" and Cisco Autonomous (FAT) APs? I am running Windows 7 Professional on a 64-bit Laptop. Symptom: - The wireless adapter connects to the wireless network - After several minutes (2-3), it drops the connection. - If you leave the connection alone, it will come back after several (5-10) minutes. Or you can reset the connection and it will come back up, but it will eventually drop again. - Wireless Signal is Excellent and the issue is NOT coverage issue - Other laptops with different Wireless adapters do NOT have any connectivity issues. - Made sure that I am running the latest BIOS, drivers, etc. from DELL - Tried using the Intel Wireless Utility instead of the Microsoft Windows Wireless tool, but it does not make any difference
Marvin
Level 3:
Top Expert:
  • Dell Master 85,242 Answers
  • Posted on Mar 14, 2017
Marvin
Dell Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024219
Points
266281
I seen no posts of problems with this device.
1 Related Answer
Anonymous
  • 2028 Answers
  • Posted on Sep 04, 2008
SOURCE: cannot stay connected to internet with wireless dell laptop for more than a minute
This will either be a driver glitch or a problem with the router or your internet provider. Start by uninstalling the wireless drivers from the device manager, then reboot. The machine will find the wireless and reinstall the drivers automatically. If this doesn't fix it, then you might want to call your internet provider and have them check out your router and connection.
1helpful
Wifi card Intel Centrino Advanced-N 6205 not fitting in designated PCI slot on new motherboard.
Make sure that the opening in the case is properly aligned with the PC slot of the notebook. If it is not - disassemble and correct - assuming a PC (the old "PCMCIA") card is what you're trying to insert.
If you're talking about a connector on the mainboard that supports a built in Wifi PCB connector cable or an expansion slot on a desktop PC, please indicate exactly what you have.
Fix wifi association problem
(a) Ensure the Wireless Device Switch is On. Just throwing that out there. Your WiFi adapter is noting down some kind of signal strength as well, yes?
(b) Try uninstalling the WiFi Adapter (Intel Centrino Advanced-N 6205 (802.11abgn 2x2), or, Atheros XSPAN HB116 802.11abgn) in Device Manager, then rebooting and let Windows reinstall the device.
(c) Try updating the drivers from here.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS There are Windows 8.1 x86 and x64 driver packages there.
(d) If the device is working fine (according to Windows) but is still not receiving or sending, then it may be some antenna problem, and you'll have to contact Fujitsu Support for repair. Make sure you've registered your new tablet with Fujitsu.
Post back with how this goes.
Can't connect to Thomson TG 712 router Intel Centrino Advanced-N 6205
Reset the router to factory. Also, be sure there are no IP address conflicts on your network. It might be that one of your routers already is using an address. DO you have multiple routers on your network?
5helpful
I cannot find the default ip address for Cisco AIR-AP1242AG-E-K9. can anyone help?
Hi, The Access Point does NOT have a default ip address
below is quick setup guide to the Access Point
http://www.cisco.com/en/US/docs/wireless/access_point/1240/quick/guide/ap1240qs.html#wp41082
Where and what (sim card only, wireless card+sim card ??) to put into an hp nc6000 laptop to have benefit of what is yet inside (or supposed to be inside like the antennas ) and access to internet ,...
A wireless card should be already be in that system. There is no SIM card. According to HP's specifications, your laptop should have one of the following wireless devices integrated into the laptop:
The HP nc6000 notebook supports a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option and can be combined with any one of the supported wireless LAN options. All integrated wireless LAN options Wi-Fi certified
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) support
802.1x standards support including EAP-TLS, Protected
EAP (PEAP) and Cisco-EAP (LEAP)
Dual antennas integrated in the display enclosure HP W500 802.11a/b/g Integrated support for 802.11a, b and g
Up to 54mbps throughput performance
Advanced Encryption Standard (AES) support Intel PRO/Wireless 2100 802.11b wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b
Up to 11mbps throughput performance Intel PRO/Wireless 2200 802.11 b/g wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b and g
Up to 11mbps throughput performance Integrated Bluetooth Designed to the Bluetooth v1.1 specification
The full information is here:
http://h18000.www1.hp.com/products/quickspecs/11794_na/11794_na.HTML
If everything is working properly, all you have to do is find your local Starbucks or other WiFi hotspot and connect.
1helpful
3answers
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Internet connection keeps dropping
That may sound like a "roaming tendency" issue, with your laptop wireless card or settings, and/or general radio interference. try checking and tweaking the advanced settings of your wireless card, and maybe check for outside interference between your computer and router. Many cards have roam settings that dictate how often they roam between APs. I too live in an apartment complex, where other neighbors have their own WiFi router and there can be interference, and "intrusion issues" :? if your equipment is not properly set and secured.
Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
2helpful
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
