Garden Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The spark plug lead has been cut at the plastic cover where it enters at the plastic body (no spark) have stripped it down but cannot get the centrifugal cluch cover off to access the HT lead, it moves freely and their is play is it pressed on to the drive?
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on Jul 20, 2011
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1576371
Points
11774
Yes it is you need to go to a local tool rental shop and rent a puller for it. There should be a nut holding it on. Once you get it off go to a electrical outlet like Grover's or fields or Ace hardware and buy a piece of heat shrink tubing to put over the damaged area that is if the wire itself is not damaged. You can wet ten the cable and slide the spark plug boot past the damaged area and slide the heat shrink tube over the damaged lighter then heat the heat shrink tube up with a pocket lighter that you can buy at any store. If you need more help let me know
4m41 2003 model starts and idle nicely but after probably 5minutes it starts to misbehave, cutting and high idling
There are a few possible reasons why your 4M41 2003 model might be cutting and idling high after 5 minutes. Clogged fuel filter: The fuel filter removes impurities from the fuel before it enters the engine. If the fuel filter is clogged, it will restrict the flow of fuel to the engine, which can lead to a variety of problems, including cutting and idling high. Bad spark plugs: Spark plugs are responsible for igniting the fuel in your engine. If the spark plugs are bad, they will not be able to ignite the fuel properly, which can lead to a variety of problems, including cutting and idling high. Low compression: Low compression can also cause a variety of problems, including cutting and idling high. Compression is the force that pushes the piston down in the cylinder, which is necessary for the engine to run properly. If the compression is low, it will be harder for the pistons to move, which can lead to a variety of problems, including cutting and idling high. Clogged injectors: Fuel injectors deliver fuel to the engine in a fine mist. If the injectors are clogged, they will not be able to deliver the fuel properly, which can lead to a variety of problems, including cutting and idling high. Mass air flow sensor: The mass air flow sensor measures the amount of air entering the engine. If the mass air flow sensor is faulty, it can provide the wrong information to the engine's computer, which can lead to a variety of problems, including cutting and idling high. Throttle body: The throttle body controls the amount of air that enters the engine. If the throttle body is dirty or malfunctioning, it can restrict the flow of air to the engine, which can lead to a variety of problems, including cutting and idling high. If you are experiencing these symptoms, it is important to have your vehicle diagnosed by a qualified mechanic to determine the root cause of the problem. Once the cause of the problem has been identified, the mechanic can recommend the necessary repairs. Here are some tips to help prevent these problems from happening in the future: Change your fuel filter according to the manufacturer's recommendations. Change your spark plugs according to the manufacturer's recommendations. Keep your engine clean and well-maintained. Avoid running your vehicle on low fuel. If you notice any problems with your vehicle's performance, have it checked out by a qualified mechanic as soon as possible.
Where is the fuse for defy daw373 frontloader washing machine
The fuse will be;
1. Inside the plug.?
2. Concealed in the plastic panel where the mains lead enters the machine body.?
On the inside of the machine, where the mains lead enters the machine body.?
Best of luck
Loose power connection on motherboard of Satellite L640D-ST2N01
Toshiba Satellite laptops often have problems with their power connections becoming loose and losing contact between the positive pin on the DC power jack and the motherboard. Laptops are not designed to operate on the battery when the AC adapter is plugged into a viable power outlet. You will have to disassemble your Toshiba Satellite laptop to repair this problem. This task requires a thorough knowledge of laptop repair and safe soldering practices.
1. Disassemble your laptop according to the instructions for your specific Toshiba Satellite laptop model. Cut the plastic supports off the base assembly with a knife.
2. Cut off the plastic wall that encircles the mount opening with the knife. Extend the circumference of the hole by carving it open with the knife to make it wide enough for the new jack.
3. Bring the ends on the negative lead for the jack together and cover the ends with solder.
4. Remove the original DC power jack and trim the wires from the jack box with the knife, until they sit close to the edge of the jack box. Use the knife to strip the wires. Use your fingers to twist the wires together, and then coat the point where they meet with fresh solder. Locate the positive wire -- it is either red or green. Plug this wire into the positive lead on the new jack, and then find the negative black wire and attach it to the negative lead on the new jack.
5. Place the new power jack in the base, keeping enough extra space available for the plastic laptop cover and right speaker to fit back in later. Cover the negative and positive leads with the electrical tape, and then manually rotate the nut on the power jack clockwise until it will go no further.
6. Figure out which walls will stand in the way of the power jack after you secure the plastic laptop cover. Cut these walls out with the knife. Reverse the disassembling instructions you followed previously to put your laptop back together.
1helpful
We have a Suzuki Vitara V6 we have mannuals etc., but we still can not find a diagram to locate the spark plugs and leads. Where can we get such information?
some times on japanes v6s the leads&plugs r covered by a plastic dust cover should run down the centre of each rocker cover
2helpful
2answers
Does my 1994 campy have spark plug wires
Did you look under the hood? YES it has spark plug wires!
1helpful
2answers
How do i locate the spark plugs for my 2004 acura rsx engine
you have to remove the plastic cover attached to top of valve cover,once removed you'll see where coils drop into cylinder head through valve cover.remove and plugs (5/8 socket)sit down below coils.
3helpful
It just stoped but will not start again changed the plug cleaned the carb
Hi, if it cut out whilst running it has either ran out of fuel or ignition. Please make sure you have plenty of fuel in it. This sounds like an ignition problem. Take the plug lead off the spark plug and stick a metal blade screwdriver into the end of the lead, then hold the screwdriver close to any piece of metal on the cylinder head close to where the spark plug screws in and get some one to crank it over by pulling the cord and holding the throttle as if you were trying to start it. You should get several sparks to jump from the screw driver across to the metal. If not you have a problem that involved a considerable amount of knowledge and stripping down of the engine covers etc to get to the offending items.
HOW MUCH IS A REPAIR FOR A 2002 PT CRUSER HEAD GASKET
Strip engine of intake manifold and throttle body.Remove spark plug leads and coils.Remove tappet cover.Clean all surfaces and fit new gasket. Reassemble engine.Sealant $1.50 Courier & tolls $8.00 Gasket valve cover $172.00 Labour $60.00.That was the account I had to pay
2helpful
HOw to get into engine to change spug pluggs and leads for Toyota estima 1993
The best thing to do is to purchase a Haynes manual for the Toyota Previa. But to access the spark plug wires and spark plugs you will need to remove the passenger front seat. This requires taking out four bolts on the four corners of the seat. After the seat is removed you need to remove the outside seat support and the jack and jack handle that is located under the seat. Next remove the bolt from the seat belt/shoulder harness. Romove the screws from the side of the carpet keeper strip along the bottom of the door. carefully, using a flat blade screwdriver, pry the plastic carpet strip up carefully disengaging it from the rear strip. Unhook the carpet from the edge of the doorway. Pull the carpet back enough to expose the bolts holding the cover over the engine. Remove all the bolts holding the cover over the engine. This will expose the engine head. remove the three bots holding the black plastic cover over the spark plug wires. This wires can be removed allowing access to the plugs. Be aware these engines use only platinum tipped spark plugs. Good Luck
Top Garden Experts
Jay Finke
Jay Finke
john h
