I have an MP3 Audio book downloaded into iTunes. When I sync iPod Nano 8G with iTunes, I get error message saying can not download the MP3 audio files. How can I fix this. Can I transfer MP3 audio files directly from the D Driver into my Nano?
It seems that you're Ipod is not detected by your computer that's why you have the problem, try connecting your ipod to another usb port on your computer, close the Itunes then open it up and check if the Itunes will detect the ipod and if yes go ahead sync the mp3..
Hope that helps........
Yes u can transfer MP3 audio files directly from the D Driver into my Nano by just attaching your i-pod to the computer.
and just makes the hidden files enabled from the folder settings.and then just transfer.its very simple.you can do it.if u are not able to do it properly.just take it to the computer shop.and they just take some minimum charges to do that and also explain yopu step by step what is the exact procedure
pls do rate the solution
thanks.
regards.
fixya expert team
try reloading the software again.may it help.but if not able to do.i will suggest you to call the engineer at you place to do it.as the cost may be not more then his service charge,and he will be having all the required software cd with him.and if some thing goes wrong it will make your i-pod corrupted.so dont make it scrap.and call a engineer.thanks.
thanks.
regards.
fixya expert team
Is that a first or second generation nana ?
Robert
Yes you can, plug the ipod into your computer, you will need to get show hidden files enabled from the folder settings and browse into the ipod and transfer the mp3 files there.
I did what was perscribed, but still did not work. When I connect iPod to computer, it is not seen in My Computer. It seems to go directly to iTunes and My Computer does not see the iPod connection. I continue to get the following error message:
"Some items in the iTune library, including forward, were not copied to the iPod because they could not be found."
Hidden files in enabled in the folder settings.
