I have a cook works kettle which suddenly stopped working since last night. It is cordless. WHen i place on the holder the light comes up but water is not getting heated/boiled
What a crazy over-complicated kettle!
Disc element kettles do tend to have a limited life that is a small fraction of the lifespan of standard kettle elements. The ones I have had usually only last until the guarantee has expired. To discover whether it is the kettle or the base it will be necessary to use a multimeter to check the supply from the base.
I've been using the same kettle on my stove for about a year and I hadn't cleaned it even once until last week.
A while ago I started noticing these weird white chucks that would come out with the water but I just figured that it was because I get a lot of use of out my kettle.
It turns out that the white chunks are actually limescale.
I did some research on it and thankfully limescale is not harmful to ingest. However, it's pretty gross to look at and I certainly wouldn't want to serve a cup of tea to a guest that is filled with strange white flakes.
So I figured out how to clean my kettle with stuff I have at home.
All you need is some regular cooking vinegar to do the descaling for you.
There is no need to buy expensive chemicals that you wouldn't feel safe using on a cooking product anyway.
Start by rinsing out your kettle with warm water.
Then, fill half of it with water and the other half with vinegar.
Place it on your stove and let it come to a rolling boil.
Then, just leave it there over night.
When you wake up in the morning, dump out the water and vinegar solution.
Take a long scrubbing brush and scrub the inside of the kettle to remove whatever limescale is left.
If there is still some caked on, you can repeat the steps over again.
If your kettle is clear of the grime, simply rinse out a number of times with soap to get rid of the vinegar taste/smell.
Voila! Your stovetop kettle is clean and no more unidentified chunks in your tea!
Whats very common on cordless kettles is the contacts inside the base get badly caboned up, You can fix it by opening up the base, and cleaning the three contacts with a disposable nail fie. Then re-assemble and it should be fine. If you can get at it, the ring and the center contact in the bottom of the kettle can also be cleaned with the file.
the filter holder has a small clip at the bottom. put the holder back in the kettle with the flat side against the kettle wall and slide down until the clip on the bottom engages in the metal holder on the kettle wall. It will clip into place and the filter can be reinserted into the holder. Without the holder in place covering the spout the automatic shutoff will not work and the kettle will boil dry.
sounds as if you have a lose wire in the base or else you element has failed. Undo the bottom of the kettle and check all wires are connected to the element. If all the wires are connect i would say your element has blown.
Indicator light is on a separate circuit than the coils that heat the kettle and water.It is unlikely you can get a replacement element to fix your issue.
Have you tried using it on a different socket outlet ? Possibly there is a problem with the wiring at this socket. If the electricity supply "trips" at the consumer unit it is either the RCD which trips due to e.g. the base of the kettle becoming wet or alternatively the MCB tripping due to an overload which shouldn't happen unless there is a fault in the kettle. When you got a replacement kettle presumably they replaced the base also?
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
