This must be a Whirlpool-made Maytag dryer and troubleshooting are therefore basically the same.
The
error code E1 indicates that the thermistor is open or having a very
high resistance. Check the wiring connections to the thermistor and make sure it is not shorted or disconnected. You may need to replace the thermistor located on the blower housing behind lower front access panel. Click on the link below for the detailed
troubleshooting of the thermistor.
Whirlpool-made Dryers Thermistor Troubleshooting
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
