SOURCE: Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
I was on this forum because I was having the same issue with a Toshiba A75 "Laptop", and I tried everything on here and on other forums and no luck. I actually just accessed the integrated wireless card panel from the bottom and removed it from its slot and disconnected the wireless wires connected and put it back on. So this has worked for me and my machine post perfectly now. Good luck to all and I hopefully this will be helpful too you.
SOURCE: Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
SOURCE: resource conflict - PCI network controller on
It sounds like your integrated wireless may be malfunctioning. You can disable the wireless from inside of the case and see if it boots up without the error message. If it works, then I would recommend purchasing an external wireless card as a replacement instead of having to replace the motherboard.
You can also try flashing the BIOS but I would definately try solution #1 first. Flashing the BIOS should be last resort!
Please let me know if you have any questions.
SOURCE: toshiba a105-s4054 won't boot
The
same machine with me and the same problem I changed the BIOS of the
motherboard but the problem Tlch the same message is is the last day I
discovered that the problem in the chip of Intel's motherboard happens
is a conflict between the PCI and Ridr and some of the various
components that vary according to the case of the slide as
this occurs in the organs contained in the slide as happens conflicts
in the delivery at the beginning of operation of laptop and since all
the inconsistencies that occur when you start up that is stored on the
memory the BIOS and therefore must be emptied this memory so that the
laptop from work and not doing a re- choose to run the key F-1
s this memory chip in it's protection for the BIOS that is stored by BIOS password
Points
for this memory on the motherboard when you connect to these points is
clear all data from storage on a slide in the Model 100 is a satellite
point of discharge under the Wireless card under the keyboard and be
written next to 88 **
As for in this model are under-Ram
