Question about Pramac 5000 Watt Generator
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow but this has not solved the problem. Can anyone help Peter mpaoo@xplornet.com
  • 3 Answers
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Posted on Jul 24, 2011
SOURCE:
I have a homelite 5000 watt portable generator that starts to run for like 5 seconds and then just stops
check sump oil level
check oil level sensor that switches off the engine if the oil is to low
check fuel flow through the tap as they corrode internally and block the flow
Dec 31, 2016 | Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Homelite 6000 Generator running rough, now won't start
Sounds like the engine is not getting enough fuel. Two possible problems:
1) I know this is a dumb question, but did you turn the fuel back on?
2) If the answer to question 1 is yes, then the small fuel filter inbetween the gas tank and carburetor probably has hardened. The inside of the fuel filter is a piece of foam and it is really common for the in line fuel filters to harden when no fuel is present and cause a clog in the fuel line. Try replacing the inline fuel filter and life should be good!
Jan 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Pramac 5000 Watt  Generator Logo
818 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
