SOURCE: Clothes do not get dry when using the sensor dry setting on GE dryer.
Ok, Jeff, I see you have a front loader, electric. On this model we have inlet thermistors, outlet thermistors, and the sensor bars are non serviceable, which means they are part of the blower housing. Not a big deal. Let's put it into a test mode and test the voltage drop of the sensors. They are on the inside of the drum just below the vent gate. 2 bars. Unplug the dryer for 30 seconds. Plug it back in and within 10 seconds press in this order: signal button, delay start, signal button again and delay start again. The consol should show t01. This is test 1. You want to turn the main dial clockwise until the test shows t09, this will be the sensor test. With the drum dry it should show around 5 volts DC. Now take a wet rag and place it over the bars, the display should show a voltage drop to around .5 or 1volt DC. If it does this the sensor is working properly. See if you can run this test successfully and post back. Catriver.
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
SOURCE: Bosch Dryer doesn't dry clothes
With the dryer not connect to the external venting turn the dryer on and see if there is air coming out ot the vent from the dryer. Is this flow of air strong or weak?
If weak then there could be a problem inside the dryer some where. Perhaps the fan is not operating properly. Just my thoughts.
You say you have check the beginning and end of the duck vent pipe. How about seeing if it venting duct is clear from one end to the other.
Good luck
SOURCE: GE Dryer model DBXR463EDIWW
If there is no lint blocking the air outlet path, I would next check two things: First, is the dryer in a small, closed room? If there is not enough space for air to get in to the dryer, it won't have good airflow through the clothes. Second, for older dryers, the blower fan may be loose on its shaft or, if the blower has its own separate motor, the blower motor might be dead. In order to find the blower fan, you'll have to be able to open up the dryer. Once you find the fan, see if it turns easily without moving the motor shaft -- if so, you need to replace the fan. Also, be sure there isn't anything blocking the blades of the fan.
SOURCE: my dryer takes long time to dry the clothes. It
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
