To help you I need to know a few things:
Does the power light on front of set come on at all?
Do you hear any kind of a click from the set when you try to turn it on?
Have you followed the power cord inside the set (with set unplugged) to the glass line fuse?
Do not rate my help here until you have told me what you found, the more you tell me the better I can help you.
SD TECH
Please feel free to comment here.
SD TECH
This would seem to be a easy one to fix; with a voltmeter follow the AC into the set and across the fuse.
Is the power supply with the fuse on separate board or down on the main board?
I have yahoo Im if you want to chat.
The fact no power light and the power relay does not click means the trouble HAS to be right where the power cord goes into the power supply in the set.
A set that is completely dead is always much easier to fix for this reason.
SD TECH
When i plug the power cord into the outlet it makes a click noise although my input jacks has are stuck into the panel
I dont know
So what should i do
THE POWER LIGHT DOES NOT COME ON,NO CLICKING SOUND,CHECK THE FUSE ITS GOOD
