Question about Bosch Nexxt 300 Series WFMC2201UC
Error code E:13
During the rince cycle the softner no longer is added and, after filling with water, the washer stopd with the error code E:13 on the display. Any insight?
  • Bosch Master
  • 19,396 Answers
I thin E13 is motor error, I will check.
Posted on Sep 03, 2008
  • Ginko
    Ginko Sep 03, 2008
    E-13 error code means 'drain timeout code'.
    This happens when the pump run a
    certian amount of time and cannot do fully draining.
    This can be commonly coused by a clogged drainline
    , a clogged pump, a faulty pump, or pump not receiving power.
    In most occasions you find something jammed
    in the pump, or the pump has blown.
    You access the pump removing the panel at the back of the washing
    machine at the base of machine. Once you get to the pump you unplug the
    two hose, remove the pump unplugging wires, and lifting the plastic
    block. Then you clean or replace the pump.
    Master:
  • 521 Answers
E13 code means Pressure switch Fault
To check :- Remove Plug First ( Remember Safety First )
The pressure switch is at the top, its move likely to be a blocked pressure bottle, which is under neath the tub accessed via the rear bottom access panel 3 to 4 screws. the bottle is on the side of the filter with a small clear tube going up to the pressure switch. Clean this bottle out.
pls do rate the solution
thanks.
regards.
fixya expert team
    Genius:
  • 3,422 Answers
Cause: Latch Problem Example: Latch does not run Corrective Action: Check for voltage to latch motor
  • Priya darshan Sep 03, 2008
    Please don't forget to accept the solution as fixya.
    Genius:
  • 1,142 Answers
E13 Water leak in tub or air leak in air bell.
  • Anonymous Sep 03, 2008
    If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code.Try to reset the maching by unplugging it for an hour and then remove the cloths then turn on the unit and try to drain the water, that should take care of it
SOURCE:
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water will not fill during rinse cycle water just keeps runningg?
That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My machine quits working during the rince cycle
the safety switch could be the culprit on this because anytime you open the door on top it triggers which turns it all off. so what i would start with is either bypassing that switch or replacing it.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Nexxt 300 Series WFMC2201UC Logo
2,265 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
