Mackie 1604 Vlz3 16 Channel Mixer Logo
Posted on Jul 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Buzz sound - Mackie 1604 Vlz3 16 Channel Mixer
Megasong
Level 2:
Scholar:
New Friend:
  • Expert 125 Answers
  • Posted on Feb 18, 2014
Megasong
Expert
Level 2:
Scholar:
New Friend:
Answers
125
Questions
0
Helped
43125
Points
141
You've made a statement, please give full information if you would like help. Is the buzz heard from the speakers or the mixer? Do you get normal sound too? Is it there with no input? Does it change with the output setting? Help yourself to get help and let us know properly what's going on.
2answers
What causes buzzing in speakers?
There are many causes of buzz, so it should be checked step by step :
- Bad connection on the input connector, or cord.
- Amplifier, basically have the block diagram like this:
25850676-l1qpqmriditabltrjczr2eku-5-0.jpg If in one block damage, buzz can be heard.In the amplifier.
Generally occurs in the PSU and / or power amplifiers.
Fix it to the experts,because it requires a good knowledge of electronics.
Blown speaker cone, does not cause a buzz.
Short circuit along the wires supplying the audio, it will not cause any sound in the speakers, including the sound of music.
Try also, disconnect the input connector, whether the buzz is still audible. If after the input connector is removed, the buzz disappears, the possibility of buzz came from another device before the amplifier.
3answers
What would cause a buzz in speakers?
- Amplifier, basically have the block diagram like this. View image.25850665-l1qpqmriditabltrjczr2eku-2-0.jpg
Only humming or buzzing , no music or sound
Try different cables. That would be the most simple and cheapest fix.
My DigiTech RP355 turns on but only buzzes
Sounds like a classic ground-loop issue. Sound-on-Sound had a great article some time back that may help you.
Apr 10, 2014 • Music
I turn on the power and get just a buzzing noise. The keyboard does not work at all. The power light is on but no sound from the keyboard other than a buzzing sound.
normally a buzzing sound means a grounding problem, or a component has failed, unless you have the proper equipment to check these items,, your going to have to take it to a shop that does, sorry I know thats not what you wanted to hear,, but heres a hint, Ive found that a shop that deals in instruments and sound devices charges a lot, I have found a TV repair shop in my town, that can check my band equipment,, and its much cheaper, and I usually get the stuff back much quicker too
Sep 01, 2011 • Akai Music
1helpful
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
New flying v, 3 strings make rattly sound near end
Are the strings hitting the frets and making a buzzing sound or is it actually coming from the bridge? Make sure the saddles on the bridge are secure. If the buzzing is caused by the fret then adjust the bridge height and/or truss rod. If the buzzing is coming from the bridge and cannot be cured it may be worth investing in an aftermarket bridge.
Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
I have a mackie 32.8
Hi there. Disconnect all auxiliary inputs. Still buzzing? Internal problem. Not buzzing? External problem.
Thanks
Paul
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
