Hello [3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit. [4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device. [5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed. OK.
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
SOURCE: Remote programing for TV after changing batteries
HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
SOURCE: remote control trisonic ts-rc444
Unfortunately, Trisonic dont publish their codes on the web. Call Trisonic toll free at 1-800-TRISONIC. I am sure the operate on a
Mon-Fri basis probably 9am-5pm. It is the only way to get your codes.They are very helpful.
When you get
your code you will need to push and hold the SET button first, then
push your device button (TV, DVD, etc)as you continue to hold the SET
button. I red light will appear on the front of your remote and it will
remain on until your enter your device code. Enter your code and hit
the power button to test your device.
This is the best and only way to get your Universal remote code. It
saves you from having to buy another remote or spend any other money.
SOURCE: H ow do I program my remote to my tv?
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV
Code 1012 for Sharp TV
Code 1026 for Sharp TV
Code 1095 for Sharp TV
Code 1111 for Sharp TV
Code 1112 for Sharp TV
Code 1171 for Sharp TV
Code 1173 for Sharp TV
