Hi There.
Symptoms
* cmos checksum error messages
* error with date time error
Solution
* Replace CMOS battery.
Procedure
1. Locate your CMOS battery.
2. Turn of your Desktop.
3. Remove the power cable from your Desktop.
4. Press power button to discharge your Desktop from electricity.
5. Desktop should be laid down horizontally.
6. Remove the battery and avoid forcing.
7. Replace the battery with same model or equivalent.
8. Put the new battery firmly in the allocated slot. (Positive side should be visible).
9. Plug the power cabe and start up your PC.
10.Enter Bios by pressing DELETE or F2 and load defaults save and quit, it will reboot automatically.
11.Enter Bios modify settings save and quit.
12.The End
Hopefully this information helps.
Thank you for using FixYa.
Check your Hardware configuration. This usually happens when you tell the system BIOS that you have for example, a second floppy or Hard Drive, when you do not. So it stops and asks you what to do next.
Hope that helps.
Eddyfix
