Thanks for choosing FixYa and welcome to the site.There are a few things that can be going on. I am not quite sure if you have power or not, but if you don't, try checking the plug in cord. If you do have power, the start button may be defective or have a bad connection. You may also have a problem with your control board in the washer, basically your computer. It is not common, but they do go out. You may have a bad lid switch as well. Pay attention to when you close the washer door. Listen for a click from the lid switch when you shut it. If you have a bad lid switch, it can even cause the washer to not work at all. Try these steps and let me know what else is going on. I will respond to your reply and thanks for choosing FixYa.
The drive motor controls the turning of the drum. If your drum is not turning, the motor may be bad. You could also have a bad lid switch also. It can cause the washer to not spin. As far as the pulley, if you have a frozen pulley, it can cause this. But you should be able to see this when the belt was changed. You can add a some type of lube to the pulley (if it is sticking) to see if it will begin to move. If not, it will need replaced.
Hello
& Welcome to FixYa If
the door is closed completely then the problem is with the control board/start
button that needs replacement. Please get back to me if you have any other
questions. Kevin
OK, as it is a dryer then it seems the belt is worn out and is bad and needs replacement, you have to open it to check it.
Belt wont turn and the dryer wont start, the start button causes this clicking noise
This is good....when you don't want to do what you are told to do, just simply reject the solution. Anyways as I told you that the belt is bad and needs replacement so please review this video:
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
This is a front load dryer, when you push the start button the dryer actually runs but it is making a clicking noise and burnt rubber smell. I dont think the drum is turning
What causes the clicking noise?
The dryer is actually running, the drum is not turning and there is a burnt smell. Dont believe it is the start button
I have a maytag front load dryer. When you push the start button the dryer starts but there is a clicking noise asnd then a burnt rubber smell. I am not sure if the drum is turning.
My problem is with a maytag ensignia dryer quite series 200. I have replaced the belt but the drum is still not turning and when you push the start button hot air is blowing, so it mustr have something to do with the motor or pulley wheel, please help
