SOURCE: no input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
SOURCE: connecting dvd player
the tv should be in video mode in order to accept input from dvd...when it does'nt work try to use a modulator that should be connected at the back through using cable with f-connector both sides...
SOURCE: No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
SOURCE: AV input selection without a remote
Depending on the model of the tv, you could scroll ch dn past ch 2 and you should cycle through your inputs. if that doesn't work try holding down the two vol buttons on the tv. that could access the menu for the tv
Press the "On" button on the symphonic TV to turn that set on.
2.
Hold down the TV button on the symphonic remote until all of the buttons on that remote flash.
3.
Type in 0053 code for the symphonic TV remote as you point the remote toward the TV.
4.
Press either the "Power" or "Pound" ("#") button on the symphonic remote to save the code
