Hi, on your Delta saw shaft has two flanges which one goes in front of the blade and the other behind the blade. These flanges have two flat spots in the center of it which over the shaft, the blade has the same cut out so you need to check your shaft, flanges and blade to make sure they are all locking on the shaft. Do not forget to unplug the saw before you do any work.
SOURCE: Delta 36-075 miter saw. Motor ok, but blade will not spin
It sounds as though one or both of the items are stripped. They mesh to drive the blade so I would not take a chance on just replacing just one. Also when you look at this you might also want to look at replacing the bearings and brushes. Make sure you clean out the gear housing or you will have immediate problems again. Also check where you buy these parts for their recommendation on the grease that needs to be used.
