The bottom panel on the dishwasher in question is fixed by four screws, two on the panel itself, concealed by white covers and two more screws under the door hidden away. I have now accessed the mains and I am going to replace the cable, as; after a wash (is this important?) when you move the top drawer back in, the circuit breaker blows.
All that I can assume is that the cable is in someway faulty.
I cannot see any other wires or cables near the point where the top drawer closes and impacts on the interior casing.
Thanks very much for your help.
Eric WoodwardThe bottom panel on the dishwasher in question is fixed by four screws, two on the panel itself, concealed by white covers and two more screws under the door hidden away. I have now accessed the mains and I am going to replace the cable, as; after a wash (is this important?) when you move the top drawer back in, the circuit breaker blows.
I shall replace the mains cable as a matter of course and see if that solves the problem. in the meantime, I shall go and wipe the kitchen floor and get rid of all the water that has leaked!
Thanks again,
regards,
Eric W
Thanks again,
regards,
Eric W
You can't post conmments that contain an email address.
Re: How do I access the mains cable termination on a...
You need to remove the 2 torx screws from the bottom panel you will see the cover or junction box on the front right side once the panel (toe kick) is removed
I HAVE SEEN WERE A MOUSE HAS CHEWED THRU THE CABLE AND CAUSED THE UNIT TO SHORT TO GROUNDSounds like A SHORT YOUR RIGHT
sounds like a small capacator in the main circuit has blown its better to buy the circuit board I bought one last week and it cost 37gbp ie stirling,go to bosch dishwasher circuit boards.com.adrian....
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure--- 1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks. 2. Tools needed: small flat blade screwdriver (for unlocking terminals). 3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals). 4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw). 5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw). 6. Clean water & debris from base, then check float operation. 7. Connect wires, then install base cover & toe kick. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance. Daniel
remove the bottom plate of the dishwasher and the bottom pan is revealed. reason the drain pump is running will be that this pan has water in it ie you have a leak. mop out the water and dishwasher will work - switch off mains when you do this
hiya, Can't solve this problem unfortunately but I however have been given a Bosch sms 4012 without the manual and was wondering if you could tell me how to make it go.
Eric Woodward
Hi Master_Tech, Email is eric dot woodward 47 at Tiscali dot co dot uk.
I am sure that you can delete the spaces and put the dots in!
regards,
Eric
Thanks again,
regards,
Eric W
