Question about Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K
Measuring a Building
What is the most accurate measuring tool for measuring a buildings height?
    New Friend:
New project in Panvel homes are the properties that people buy as their vacation retreats. These homes are usually sought after in green areas away from the maddening crowd of city and its hustle-bustle. https://www.spaceindia.in/ongoing.php
Posted on Nov 20, 2018
    Problem Solver:
  • 14 Answers
The most accurate method for measuring a building is suprisingly the building's own shadow. take a yardstick or a ruler and stand it up next to the building and measure the shadow. then measure the building's shadow and divide the 2nd measurement by the 1st. for example the ruler measures 8 inches and the building measures 80inches then we know the building is 10 ft tall
Posted on Feb 27, 2009
  • 30 Answers
This is a pretty odd question, i think you don't need to measure it, you can check the building plans.
If you insist on measuring it I think your best option is a Laser Measuring Device, they are the easist to use.
Posted on Aug 28, 2008
SOURCE:
I want to have a loft conversion, what size and spec do the floor joists have to be
You Can HAve Either A 2 x8 Or 2x10 Joist This Will Cover ou In Cast You Have Alot Of Stuff And The Joist Size Will Be Able To Carry The Load And Weight,
Hope I Have Helped You In Your Inquirey,
GAlway John
Jul 16, 2010 | RTO M-D Building Products Carpentry &...
I have a 16' x 16' building to put up what is the diagonal so I can keep it square
to keep your building square you mark out with stakes 16 ft.all four corners,now the corner that you like thats in the area of choice,you have to measure corner to corner so that you have the same measurment then you will be square.
Mar 19, 2010 | Square M-D Building Products 27870 16X24...
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
My daughter needs to build San Juan Bautista Mission
milk-quart-1/2pint cartons ,egg.cartons and empty tube from paper towels spray paint
Feb 22, 2010 | RTO M-D Building Products Carpentry &...
Use of bosch dlr165 when there is no direct line of vision
northerntool.com has a few wheel meters that roll along the ground and will give you a fairly close measurement. or you can use the string method where you take a string and stretch it as close to a straight line as possible then mark it then get it out to where you can measure the string.
Dec 24, 2009 | Bosch DLR165K Laser Rangefinder Kit
How can a building act as a climatic filter? How did it come that man should build? I have been giving assignment and i have done my best to get answers for those two questions i have asked but i have not...
You want to filter the climate? Which part, how much, what do you want to remove from the climate? Man builds for something to do so that he doesn't have to think about his precarious position before GOD.
Oct 04, 2009 | General M-D Building Products Purpose Box...
Building a floor to ceiling built-in bedroom cupboard
First you need proper tools there are books out there that have projects like this that aren't necessarily the same size but give you a good starting point and tell you what tools you need.
Second get a friend or friend of a friend that has some knowledge of carpentry I do not recommend someone with little or no skill to try and tackle a project like this.
Last see what space you have to work with and what you would like to do with that space get rough measurements and see how much material and hardware you would need.
Again I stress make sure you have someone to help guide you in your endevour.
Sep 28, 2009 | RTO M-D Building Products Carpentry &...
Big cliff height measurment?
You could do a bit of research as i can't remember the math's from my college days, but, it is possible to calculate the distance something travels by using its rate of descent against the time it takes to reach the ground, for instance, if gravity is measured at 9.81N/m per sec squared, then an object must speed up at the same rate from standstil every time unless the earths gravitational pull changed. If you then timed how long it takes to hit the ground you could do a simple calculation offsetting the rate of descent against time which would then give your distance. The calculation is - distance = speed x time, but you would need to factor in the the rate of change in the speed of the object from standstill to finish which is the bit i can't remember.
Aug 27, 2008 | Stanley 100 ft. Tape Measure, FatMax
Dewalt Self-Leveling Line Laser Horizontal&Vertical - DW087K Logo
512 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
ka4iup
ka4iup
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
