Mitsubishi WD-62827 62" Television Logo
thomas kivett Posted on Aug 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No one has been able to give me an answer
Hi there. I have a problem that NO-ONE has been able to assist. It is a very technical problem. Here goes: I get white, broken, horizonal, flashing lines at the top of the tv screen. It only happens in the HD format, [720p or 1080i].--Also it comes and goes! It's very wierd. For example, it will do it during a commercial, and then when another commercial comes on, it will go away. -- What is wrong with my beautiful HD television??-- Thomas K.
  • arcdodson Jan 11, 2009
    My Panasonic plasma does the same thing. There is a line at the top of the picture. It happens on almost every HD channel. It seems like I need a vertical adjustment, but there isn't one on my television. How do I fix this??? It's very frustrating.
  • Anonymous Jan 13, 2009
    I had a 42" wetinghouse and now have a 47" Vizio, both had the same problem. Im not sure it fixes it if you adjust the verticle, it just hides it. I can do that and it will show up in PiP. wierd. My brother had the problem and the line started growing! And it completely ate his screen after awhile. Will and can this happen and wouldnt it be easier and cheaper to just take it back than checking electrolytic caps?Who the hell knows what that is besides you? And the nteinc.com website wants me to join, no thanks and I dont understand it anyway. :/
Anonymous
Level 3:
  • Master 579 Answers
  • Posted on Aug 28, 2008
Anonymous
Master
Level 3:
Answers
579
Questions
Helped
215716
Points
1286
Sounds like insufficient vertical sweep and the top lines are getting out of control.
Check all the electrolytic caps in the vertical circuit for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. Look the I.C. up in the free NTE crossreference at nteinc.com get a diagram of its pinout to find what pins the power and outputs are on.
Hope ya fix it!
Hi i have isuzu rodeo auto 2007 would like to know what iol goes in transfer box please
its gear oil should have the specifications in manufacturers manual in glove box a quick call to u r local autoparts to order gear oil will give that answer by year ,make ,model they will assist you its part of the service to make sure you buy the good products you should be good
1helpful
Ft 720r memory
Hi Mike,
Not that I'm aware of, instead of backup battery, your unit has an EEPROM, which is the memory storage facility, and if this fails, then there's your answer, it will need replacement.
If this is the case and you're not technically minded, then take it to a 2-way radio service centre, preferably yaesu authorised, and have them make an assesment and give you a quote re: repairs, otherwise if you know any HAM RADIO operators out there, ask them to assist, it wiould cast far less that way.
I hope I have been of some help to you.
Regards,
Peter
My LG Optimus turns itself OFF on its own. Is there a timer function with this phone?
To answer your question : NO there is no timer set for that phone to automatically shut down, This is a known issue for this phone, So i would suggest to go back to the retailer store you purchased this, it have it replaced by a new (If You still have a warranty ).
Or you can call LG technical support regarding this issue:
Contact by Telephone Toll Free: 1 (800) 793-8896
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
Nerdierob
3helpful
4answers
How much does it cost to join and does it cost to ask your mechanics questions thankyou
just sign in no cost, ask or give your info, just try to be the best you can and word things in plain english and give honest advice to the best of your knowledge. welcome, this is a helpful forum platform.
I have lost my cd to install for my belkin router what shall i do ?
Hi i got your issue
no problem if you lost the installion Cd
Step 1: Contact belkin customer support 18002235546 and select IVR option 5 4 2....they will give You a free cd
Step 2: Or contact belkin technical support 18002235546 and they will assist in installing the router witout the cd
Thank you:
Priya
Hi , All the keys and the buttons on my nokia N95 have just stopped working this afternoon. Any ideas please ?
Dear user make sure its not water damaged if its so then give it for technical assistance to its technical department.... or due to too much data it got helded
3helpful
2answers
Hi, I need a manual for LG LD2131 SH
Hi
Thanks for using FixYa. You can download the user manual for your dishwasher from this link--
LG LD 2131 SH Dishwasher User Manual
Please revert for further assistance.
Thanks
Rylee
Hp 640 cant send or receive fax(NO ANSWER FROM REMOTE FAX
Since the fax machine is about 4 weeks old, why not give it back to HP? Warranty still covers it.
Safety
Hi Charlie, I am going to give you an honest answer as opposed to the technical one, because any lawyer who has never used a tool can tell you for safety you need to stay 12 inches from the blade therefore we will give you a 16 inch stick. The honest answer is that stick is so you can keep all of your fingers in one piece and you should use the stick anytime your fingers or anything else can get close enough to lose em. Common sense should prevail. Oh and by the way, as far as safety goes there should be a giant red arrow on the tabletop so people don't feed wood into a table saw the wrong direction! Good Luck to you, Hope this Fixsya!
Mar 20, 2009 • Delta Saws
1210M5G- warped sound on most records.
I answered here:
http://www.fixya.com/support/t303119-technic_sl_1210m5g_problem
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
