Washing Machines Logo
Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after. Occasionally the f12 error sigh shows.
Anonymous
Level 3:
Guru:
  • Master 500 Answers
  • Posted on Jul 18, 2011
Anonymous
Master
Level 3:
Guru:
Answers
500
Questions
Helped
203140
Points
1335
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Bosch exxcel washing machine/dryer
Is it waiting to heat up? Try it on a spin cycle and see if it stops. If not, it may be a thermostat fault or heater element not working. Worst case may be timer faulty
Wash cycle over running
the main control is not advancing properly and needs to be replaced,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
The washing machine is taking longer time
You can check that pump filter which is behind the base plinth, also check that the water entering the machine is at a reasonable pressure. If the machine is taking a longer time to wash and both inlet and the outlet of water is ok, it is more than likely a wash side heater fault. Basically, you set, for example. a 40 degree cycle, the heater does not operate and the water never reaches the required temp, the machine ventually times out on the heat phase and then moves on to the rinses or aborts to the end of the cycle.
1helpful
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2helpful
2answers
Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
