You will find to set the language in this manual:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00575070/c00575070.pdf
There is also the possibility to change the settings via Web Server. You will find in the same manual how to use the Web server.
Hi you need to go factory settings mode.
To perform a cold reset
1.Turn the printer off.
2.Turn the printer on. When the printer begins its memory count, press and hold down
three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
3.Release
4.After SELECT LANGUAGE appears on the control-panel display.
