SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
SOURCE: pump stops running on high speed
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
SOURCE: Z110 jacuzzi heater keeps cutting off after 30
The water temperature needs replacing not the high limit found usually in the filter well
