This may clear the ink absorber.
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
SOURCE: my printer is canon ip1980." ink absorber is almost full
My inkjet printer no. IP1980 is ink absorber is full. Please help me.
SOURCE: canon pixma mp160 ink absorber is full
this the reset wast ink please follow it step by step
SOURCE: reset ink level for printer canon pixma ip1980
http://indoresetter.blogspot.com/2008/12/resetter-printer-pixma-ip1980.html
go to this link and download resetter......
SOURCE: Canon Pixma ip1300 Ink absorber is full what can i do
another solution for a quick override is to unplug the power lead from the back of the printer. With one hand hold down the power button on the printer whilst simultaneously plugging back in the power lead. When the light is back on, take your finger off the power button. You may need to press the power button once more, but this should 'override' the problem until the next time you turn your printer off.
SOURCE: canon ip 1300 ink absorber is full. how to empty
is there a program that can disable the waste pad ink full? just like ssc utility for epson c45?
