Mine died too. I called American Standard. They gave me the updated pump part number. It is: 752538-0070a. You can find them everywhere in the internet. I just purchased one for $185 shipped.Mine died too. I called American Standard. They gave me the updated pump part number. It is: 752538-0070a. You can find them everywhere in the internet. I just purchased one for $185 shipped.
You can't post conmments that contain an email address.
Hello my name is Israel and I will try to help you out. The thermostat housing in located on the water pump. I have enclosed a picture of the water pump and thermostat housing pointed out by the arrow. Please rate the information, good luck.
Hello dglhgl8: My name is Roger and I will help you. The fuel pump on this vehicle is located inside of the fuel tank. Th gain access to the fuel pump you must drop the fuel tank in order to gain access to it. Should you need further help please just ask Please rate the answer. Thank You for using Fix Ya. Roger
Hello batljones: My name is Roger and i will help with your question. The fuel pump is located inside of the fuel tank. You will need to drop the fuel tank in order to gain access to the fuel pump and strainer. Be sure to replace the strainer and the fuel filter or your warranty on the pump will be void. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Hello wellhead57: My name is Roger and I will help you. The fuel pump is located in side of the fuel tank. You must drop the fuel tank to gain access to replace the pump. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Hello conley1959: My name is Roger and I will help you. The fuel pump is located inside of the fuel tank. You must drop the fuel tank in order to gain access to the pump unit. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Hello ririshrusso: My name is Roger and I will help you. The fuel pump on your car is located inside of the fuel tank. You must drop the fuel tank to gain access to the pump. Should you need further help please just ask. Please rate the answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
Hello lonniesway: My name is Roger and I can help you. The fuel pump on your car is located in the fuel tank. To access the pump you will need to drop the fuel tank. Should you need further help please just ask. Please rate the answer. This way i know it was helpful. Thank You for using Fix Ya. Roger
Hello rand1958: My name is Roger and I will help. The fuel pump is located in the fuel tank. You can access the pump by removing the rear seat cushion. Remove the 4 screws in the floor cover. unplug the fuel pump wire harness. Remove the fuel line locks. BE CAREFUL as fuel lines may be under pressure. Remove pump lock ring to remove the fuel pump. I would also recommend replacing the fuel filter at the same time. Should you need further help please just ask. Please rate the answer as this way I know it was helpful. Thank You for using Fix Ya. Roger
Hello baas60: My name is Roger andI will help you. The fuel pump on the 1996 Ford Taurus is located in the fuel tank. THe best way to access the pump is from underneath the car. You will need to drop the fuel tank in order to gain access to the pump. this is best done on a hoist. Should you need further help please just ask. Please rate the answer you received. This way I know it was helpful. Thank You for using Fix Ya. Roger
