Price Pfister Savannah Two-Handle Kitchen Faucet with Matching Spray .... Logo
Posted on Dec 05, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Savannah Price Pfister kitchen faucet (double handle) - the handles do not leak but the base of the spout riser leaks. I assume I need to replace the O Ring but how do I get only the spout off verses taking the entier faucet off??? Be overly detailed because I am a single mom and need serious help with this.
Paul Carew
Level 3:
  • Price Pfister Master 3,808 Answers
  • Posted on Dec 09, 2017
Paul Carew
Level 3:
Answers
3808
Questions
Helped
1299239
Points
10526
Google your faucet and add how to fix leak there is a video on there site that shows you how to do it .
1 Related Answer
Anonymous
  • 145 Answers
  • Posted on May 23, 2010
SOURCE: i cant get the price pfister faucet out of kitchen...
There are several nuts on a faucet but I'm assuming you mean the plastic nuts that hold the faucet to the sink. They many times do jam up. To get them off you need to use a large flat head screw driver and a hammer and chisel them off. Chisel from the outside edge in toward the threads on two different sides.
5helpful
Price pfister pull out kitchen faucet starting leaking suddenly and profusely at base, from joint segments along handle base, directly under handle and possibly at base of faucet. Understand I need to...
Most likely it is under the label , it is normally put on with light adhesive. That is where the set screw is most cases. As far as leak goes, your on right track with 0 rings/gaskets. Be careful however, some time you can just get one at hardware store ( whole unit) already together almost as cheek as repairing this unless it is just a couple 0 rings.
We just installed the Price Pfister Hanover Single Handle faucet in our kitchen. (Series T529). We find that it doesn't have the same pressure as our previous faucet. Is there a reason for this? We have...
Hey,
We have the same problem. Just called Price Pfister with the same question, and she offered to courier replacement parts free of charge. She was much too accomodating. My suspicion is that she gets this question quite regularly. Love to know if anyone has solved this problem as we like the look of the faucet.
The spout of my faucet keeps blowing off when I turn the water on, what do i do?
First this is a very unusual assurance and the spout retainer ring needs to be replaced.
To help relieve the pressure on this part for the time being by removing the aerator it is probably plugged up anyway.
1helpful
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
1helpful
Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Aug 23, 2009 • Plumbing
2answers
Installed a new price pfister two knob kitchen faucet and the cold faucet turns off backwards. How do I make it shut off in the right direction ? Thanks !
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
3helpful
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Top Price Pfister Plumbing Experts
john h
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
