Hi, I have an Electrolux EWF 1074 front loader. Over the weekend it stopped draining. Cleared the Drain filter and it worked again then stopped, looked at the Drain filter again and found another item in there which I removed, however not the machine wont start any cycle. No error messages, and when you turn the selector dial it does display the time for each cycle as it always has, however the pause button is continually flashing.... Any ideas on what the issue mught be would be GREATLY appreciated...
Go back and check your connections. If you had the machine working previously and none of these issues were there before you cleaned out the drain area of the unit then your first step would be to check the connection to the pump as well as your connections going from the control to the door area as well. If after you have checked all your connections to the pump the door lock assembly, the control and the touch pad the unit is still doing the same thing then message me back. Before you do any of the checking of connections in the unit first hold down delay and extra rinse buttons together for 3-5 seconds. This usually will unlock the control if the control is locked on the unit. Also if the delay and extra rinse and the checking of your connections does not solve your issue then also message me back with the number of times the pause button is flashing and how often it flashes as well. If you have any further questions message me those back as well. I await your reply Thanks again Rick
U need to replace the drain pump. The machine will not start any cycle because it detects a bad drain pump.
Thanks for the information, although just wondering if there may be anyother options to try first as the machine did start again after it stopped the first time. I shut the power off to it for a little while the first time and it seemed to reset.....
Thanks :) The Delay and Extra Rinse button combo worked a treat and the machine is now functional again! Your assistance is greatly asppreciated.
