Yes, it's fine. Even though you have to select which phone you have, it will detect the current software version you have before updating and advise you whether there is an update available. This holds true for all SE phones with the "i" suffix.
I'd recommend reflashing your K810i via the Wotan website. You can browse & find a Dutch language version. It's all explained online. Cost is 1.99 Euro for five flashes.
This service doesn't unlock your phone (it's unlocked anyway) but it will remove carrier branding on either a locked or unlocked handset. Sony Ericsson K810 Firmware Flashing
There are a couple of ways to do this. Many cell providers will send set-up data directly to your handset, including email settings, so search their websites or ask a customer rep.
Another way is to manually enter the settings. Here are two references should you choose that path.
It seems your mobile is just an patch unlock so every time you update your phone it will lock to its original provider, but if the erom and gdfd_sw_bin if flash,it will permanently unlock and you can use any sim provider no matter how many update you make. This method is so technical and it will be fixed by using gsm gadget instead,most mobile service center have this tool. instead of asking for a paid unlock code which is more expensive, unlocking service by going to any the neatest mobile service center is more cheater and it is negotiable instead than online unlocking service.
There is the Sony Ericsson Update Service (details on the SE Webiste) however this will only update the firmware, it won't re-install the firmware. Specific equipment is required to flash the firmware on a SE K810i, you will need to take the phone to a reputable mobile phone engineer or SE Service Point.
let it sit in the charger for 1hour then try to turn on your phone. it could be that the charger cannot charge the battery and turn on the phone at the same time and the battery is too weak to turn it on and needs a better charge.
To run Settings download: Press menu on fone Go to Settings,,..then Setup Wizzard then Settings Download then press select this should then contact the provider for settings for fone ;-)
1. Disable Windows Update a. Click on start b. Click on all programs c. Click on accessories d. Click on Run e. Type services.msc and press ok f. Right click on "Windows Update" g. Click on stop (Windows Update is now disabled) 2. Rename Software Distribution folder a. Navigate to: C:/Windows/ b. Find the folder named: “SoftwareDistribution” c. Rename that folder to something like “SoftwareDistribution.old” d. Create a new folder called “SoftwareDistribution” 3. Enable Windows Update a. Click on start b. Click on all programs c. Click on accessories d. Click on Run e. Type services.msc and press ok f. Right click on windows update g. Click on start If you are unable to find Software Distribution Folder, follow these steps before #2 above. 1. From the explorer window press the Alt key to view the file menu. 2. Click Tools 3. Select Folder Options 4. Select the View tab 5. Select “Show hidden files and folders” 6. Remove the selection from “Hide protected operating system files” 7. Click OK
I have the same problem
it not support the other softwares like antivirus and others
