SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
SOURCE: H350 HEADSET
you may have the earpiece volume too low, because you will only recieve a bleep when there is an incoming call, not a ringing tone, or just set it to auto answer in the phone settings.
SOURCE: it's paired up with treo, but when treo rings, the headset will not work.
there are known compatability issues with palm treo and blackberry phones when trying to use this type of headset .
I recomend a Plantronics brand headset with your phone.
SOURCE: HS 850 won't go into pairing mode
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
SOURCE: How do I get my Motorola Elite Flip bluetooth headset to stop echoing on the other end?
Alesia-
Try a reset: ELITE FLIP Reset to factory default
Try changing setting: MotoSpeak 3 0 Noise Cancellation settings
What device are you connected to? I see other have reported after an android update on NON-Moto Devices: Headset echo problems after Android 4 3 update Verizon Wireless Community
Mark
Motorola Support
