Back to:
Tags:
Quantum HD Fireball CX 6.4 GB  Hard Drive
Wanting to use as slave hard drive
posted by ronrayhall on Aug 28, 2008
i need to know what jumper pins i need to cover or pull out
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by Arius, posted on Aug 28, 2008
what is the brand of your HDD? normally all HDD have diagram on the top of it (you wont miss this see the top sticker) and can help you identify which one to select either master, slave or cable select
Solution #1
posted on Sep 16, 2008
Not Rated (0)
ariluvsfixya
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
hi ronrayhall,
I installed a maxtor hard drive, and they are shipped with a default of cable select. If you have this hard drive you dont need to change the jumpers. You do need to make sure however your original hard drive is also on cable select.
If you dont have a maxtor, alot of manuf. print the jumper settings on the hard drive, if not you might have to find the install instructions on the web for that drive. There is a good listing of Jumper settings at this website if its easier for you than searching the web. http://drivejumper.com/
ariluvsfixya
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on wanting to use as slave hard drive:
I don't want to Accept this solution
Can you Help with these Hard Drives problems?
Hard Drives
my problem is I just connect my Hard Drive to the pc and...
Hard Drives
how to format and install a os
Hard Drives
Hi I am hoping you could help me. I have a Verbatim...
Hard Drives
I am looking for a driver for masscool uhb-330lu to be...
Hard Drives
After windows XP system all my personal files and emails...
Loading problems.
Repair Service
Find Hard Drive Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
