Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
