Pentax Optio S4i Digital Camera Logo
A
Anonymous Posted on Sep 08, 2005
S4i video problem
I just picked up an S4i and everything is fine except the video mode. The problem is viewing the video in ACDsee. There is sound, but the picture is not displayed. Only a few green static lines appear. Is there something I'm missing re: settings?
Anonymous
Level 3:
Master:
  • Master 542 Answers
  • Posted on Sep 08, 2005
Anonymous
Master
Level 3:
Master:
Answers
542
Questions
37
Helped
55330
Points
1594
A solution could be to re-install the software, but if the video file is corrupted (can happen) then I guess that there's no other solution than re-recording it.
Anonymous
Level 3:
Master:
Anonymous
Master
Level 3:
Master:
Answers
542
Questions
37
Helped
55330
Points
1594
I don't think ACDsee works with the videos from the camera (I've had troubles even trying to play music files). The best thing to do IMO would be to use the quicktime player, since its a lot more stable and faster than windows media. If you don't have quicktime installed, you can download it here: http://www.apple.com/quicktime/download/ Maybe you've tried this already, so tell me if you still have problems with it!
Anonymous
Level 3:
Master:
Anonymous
Master
Level 3:
Master:
Answers
542
Questions
37
Helped
55330
Points
1594
I have only had my S4i for three weeks now and haven't played too extensively yet. Since I want to upgrade my Mac I haven't installed any of the programs provided by Pentax. And everything works under Jaguar. I connect the camera with the USB cable and switch it on. The Mac then launches a small program just to retrieve all the files I've designated. (I don't know the English name of the program but it is native of Mac OS X and it also transfers files from the camera to iPhoto.) I have set this program to automatically start a slide show (also native OS X) of the images captured. All files, jpg, wav and avi, by then are already in the specified folder. If there are wav or avi files QuickTime launches automatically and all I have to do is click on the play button. If you have OS X I advice you to go to the preferences of the programs provided by Pentax and set them so they won't autolaunch when you attach the camera. (I had to go to the preferences of my photo loading program to prevent iPhoto from launching and having the images transferred straight into iPhoto.) Then attach your S4i and see what happens. The odds of you having OS X are slim and I have no knowledge of Windows. Still I assume Windows should be able to do the same tricks without programs like ACDSee. One thing I noticed is that my system is not happy when I switch off the camera before having removed the device from my desktop. Likewise for disconnecting. It warns this may result in loss of data. If I weren't of any help I expect someone else will. Alternatively you could send an e-mail to Pentax. Good luck and tell us how you fared.
Anonymous
Level 3:
Master:
Anonymous
Master
Level 3:
Master:
Answers
542
Questions
37
Helped
55330
Points
1594
In the set up menu you need to set the video out to PAL or NTSC depending where you are in the world.
15helpful
Acdsee pro7 serial
Download link http://filesrightnow.com/0t8G63 for ACDSee Pro 7 Keygen by CORE group. With this Keymaker you can register ACDSee Pro 7 in no time.
Watch video tutorial on link Full ACDSee Pro 7
Repair tool is not working on some photos
I had the same problem.
Scan the negatives in color mode and then convert to b&w in ACDSEE. The repair tool will now work on that negative.
I used the disk that my PENTAX OPTIO S4i came with, and it successfully downloaded ACDSee on my computer. However, when I plug the camera itself into the USB and turn it on, it is not recognised. It says...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Cannot see what im shooting and on lcd screen,no picture jus black. It shows numbers timer everything else except picture. In play mode everything works fine.
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
1helpful
Windows xp does not recognize optio s 4i
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ACDSee or any other photo cataloging program.
1helpful
ACDsee Pro2 compatibility with Vista Bussiness
Right click on the start-up icon for ACDsee Pro. You will see a menu box appear that says Compatibility. Check the option to run the program in compatibility mode for an older version of windows. Restart Windows and start ACDsee Pro - should have no more problems
ACDSEE with F55 ??
Unfortunately you can't use ACDSee to access your images on the F55. Not unless Sony comes up with a twain driver which seems unlikely. I have to use Picture gear to access the images and transfer them to my PC which I then use ACDSee to view. I also got a floppy adapter.
3answers
Optio S4i - Freezing problem on green switch
I don't know for sure, but it sounds like it could be a memory card problem. Have you tried it with another card or no card at all? My S4i froze up completely from a bad sd card. The green power button would light up, but nothing else would happen. Pentax recommends Lexar or Panasonic sd cards from what I have heard. My new Lexar card hasn't had any issues.
Problem in my Pentax s4i
This happens if you go from movie mode into green mode. If this wasn't the case with your freeze, it could be a problem with the memory card.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
