Anonymous Posted on Jul 17, 2011
I HAVE A TEAC REEL TO REEL ITS MISSING THE POWER CORD WHERE CAN I GET ONE
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jul 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
800
Points
33
Remove old power cord and replace with any power cord with similar connections from Home Depot or Lowes.
  • 1 more comment
  • Anonymous Jul 17, 2011
    ok thank you how do i do that take the back off and replace the hole unit
    Yes, take the back off and disconnect the power cord. Take that with you to the store to get one similar. Only the power cord needs replaced.
    ok thank you ill try that
1helpful
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
1helpful
Will teac rc-120 remote work with teac a-3440
No. It requires a newer type of the RC90 or RC70 models with 12 pin rectangular plug
Power cord teac A1200U
You can try and get one off E bay but I have seen the jack replaced on those with standard IEC types and then you can use any in hand computer type power cable. From being in radio I have hundreds of them- they are used in equipment other than computers.
Teac x-3 belt kit reel to reel
Marrs Communications has belts for a lot of different models. I have bought from Fred Marrs before and his belts are the high end ones not Chinese garbage. That's who I would contact.
http://marrscommunications.com/
2helpful
2answers
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
2answers
TEAC 2000R SITTING FOR WHILE NOW WILLNOT PLAY
This sounds like the solonoids are not working. This can be a power supply problem, a control problem, or the solonoids themselves. In any case, this will need to see a service shop. Where are you located?
Dan
2helpful
2answers
TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
2answers
Reel to reel tape
did a lot of surfing,and found a number in yellow pages,made some calls.and found a supplier thankssssss. vasili..
 Grubhead
Grubhead
SmartAviator
SmartAviator
