If you remove the six screws holding the base of the lamp together (one is under a rubber foot), you will find a circuit board which controls all functions of the lamp. Look for a small 1A fuse that is located on the top side of the board. Remove and replace with a new fuse. I purchased a pack of two in the electrical dept. at Ace Hardware. Everything on mine now works again!
Mine was UNDER the circuit board, I popped it out and hope to heck to be able to get it back in.
We opened ours and can't find a fuse anywhere. Looked behind circuit board. :(
Big help, my husband removed the one that came with it and can't find it. Now I know what to purchase.
Does anyone know where to find a diagram for the circuit board or that is able to post a photo of theirs?
I can’t find where the fuse is
I did finally find where the fuse is it’s in the little black rectangle box you have to remove the 2 screws and open up the box
I replaced the fuse, but the lamp itself isn't working. The night light and sounds are fine. are there 2 fuses?
I replaced the fuse and now the main light flickers is that a diode going bad?
I removed the bottom six screws but I can't get the bottom of this lamp to come off is there something I'm missing?
