Keurig B50 Coffee Maker Logo
Posted on Jul 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My keurig leaks from the bottom only when brewing coffee. Can it be fixed?
Anonymous
Level 3:
  • Keurig Master 43,501 Answers
  • Posted on Sep 04, 2011
Anonymous
Keurig Master
Level 3:
Answers
43501
Questions
0
Helped
10844451
Points
101584
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
  • lvck101
    lvck101 May 14, 2014
    Could you post your solution again, your tip is no longer available. Thank you.
5 Related Answers
Anonymous
  • Posted on Apr 20, 2010
SOURCE: Does not pump water to brew coffee
i have the same problem.
A
Anonymous
  • Posted on Aug 17, 2008
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Anonymous
  • 25 Answers
  • Posted on May 14, 2009
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Anonymous
  • 28 Answers
  • Posted on Feb 07, 2010
SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Anonymous
  • 58 Answers
  • Posted on Jun 24, 2010
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Keurig packets leaks grounds into the cup
Hi!
Here you can find manuals to Keurig coffee makers. Hope it will help you find a solution.
https://manualsbrain.com/en/brands/keurig/coffee-makers
Keurig Leaks Water Before Brewing
If it is in warranty, this unit needs factory services. Unfortunately the cheap labor and rapid production rates are more important to the company than Quality.
Whenits brewing water power out fron the bottom
heatman101
15helpful
3answers
My keurig will not brew. It says it is brewing but the water level is not going down and it is not brewing
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
