Question about Plumbing
I have a single handle belanger shower faucet- replaced cartridge and no hot water , Need help
  • 4,363 Answers
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Posted on Jul 17, 2011
SOURCE:
Moen single handle tub/shower valve . No hot water, cold OK. Nearby shower same vlave works fine. Cartridge "looks" OK. What next,
Even if the cartridge looks good from the outside I have had them plug up internally with mineral deposits. I would remove cartridge and replace it.Hope this helps.Thank you
Mar 28, 2011 | Moen & One Handle Tub & Shower Faucet
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
Th hot water side of single handle shower faucet does not work, cold side works
most likely it is the cartridge,if you replace it this may fix this problem.you must remove the handle and a pin at the top of the cartridge,first make sure the water is off to the unit then proceed.
Jul 29, 2009 | Moen 3175 Legend One Handle Shower Faucet...
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Moen one control shower faucet is leaking hot water
Try replacing the cartridge first.That's your best bit . Next would be the whole valve. Hopefully, it's just the cartridge.
Jul 04, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
508 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
