Acer Aspire 5580 Notebook Logo
Posted on Jul 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Had to reboot using alt and f10. went through whole process but blue rectangle with "thank you fo choosing acer" won't go away! pointer is a cirlce when over it. how do i get rid of it?
  • 4 more comments
  • vmcm5657 Jul 17, 2011
    right clicked on start and chose properties. does not have a hardware tab. only taskbar,start menu, notification area and toolbars! What am i doing wrong?
    hi, starting from the beginning! When i start up and perss f8 it takes me to a screen with several options. repair computer, safe mode, safe mode with networking and safe mode with command prompts. I highlight safe mode and press enter. is this correct?
    ok, i right clicked on "Start", pop up screen shows open, explore ,search, properties. i left clicked on properties and get a task bar and start menu properties window. it has the following tabs, taskbar,start menu, notification area and toolbars. it does not have a hardware tab.
    there is no hardware icon. is there another way into this part?
    I has to reboot my c drive using alt f10 on my acer 5580 notebook. it went through the whole process of setting up windows and then the launch manager was installing software drivers. It goes through this process with a blue rectangle screen which has the message "thank you for choosing acer". This blue screen does not clear and when the pointer is over the blue part of the screen it is a cirlce as if it is doing something but nothing happens. I can't do anything else on the computer as all windows open behind this blue rectangle. Help please!
    Managed to get the computer back into the recovery in f10 and rebooted again. problme resolved itself
Anonymous
Level 3:
Guru:
  • Master 610 Answers
  • Posted on Jul 17, 2011
Anonymous
Master
Level 3:
Guru:
Answers
610
Questions
0
Helped
175361
Points
1784
If you already restored your computer to factory default settings and it hangs on the initial screen of ACER, then that means that this is a hardware problem. It means one POST (power on self test) component is failing that is why it freezes on the initial screen.
If you are comfortable in servicing laptops, you can tear it down and test these three major components. RAM, Video Card and Processor.
If not, Please bring your laptop to the nearest service center especially if you still have a warranty on it.
Hope this helps.
  • Anonymous Jul 17, 2011
    Glad to hear that the restore to factory default settings worked. Thanks for using Fixya.
Anonymous
Level 3:
Genius:
  • Master 1,196 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1196
Questions
0
Helped
209535
Points
3559
Turn off your laptop. Power it up again. Press "F8" as the computer boots up. A boot menu will appear. Select "Safe Mode" from the list of options. Click "Yes" on the next menu to start your machine in Safe Mode. Right-click "Start" once the laptop boots up. Click "Properties. Select the "Device Manager" option under the "Hardware" tab in the window that appears. Find the "Display Adapter" icon. Right-click on it and select "Uninstall." Select the display driver from its location on your laptop when prompted. The display driver will be reinstalled. Restart the laptop when prompted. This should fix the problem.
  • 2 more comments
    Check very well, there is something you are doing wrong, because when you right click on the start menu, you should have properties from the small box that pop up, please check very well.
    YES, it is very correct.
    Click on each of the icon displayed to search for the hardware icon.
    Ok, let us try another way out, this is another procedure entirely, Find the name of the file that caused the error within the blue screen
    message. It is located at the end of the line of text beginning with
    "The problem seems to be caused by the following file." Note the file
    name. Turn off your laptop. Boot it up again and press "F8" to enter the boot menu a second time. Start the laptop in Safe Mode.
    Click "Start" once the laptop boots up. Open the "Search" window and
    type the name of the file you wrote down from the blue screen error
    message. Ensure the "All Files and Folders" option and the "Search
    Hidden Files and Folders" option under the "Advanced" tab are checked. Type the name of the file into the "Search" bar. Right-click on the file
    when it appears in the box and choose the "Open Containing Folder"
    option. The folder that contains the corrupt file will open on your
    screen. Right-click on it and choose "Delete." Open the laptop'
    Recycle Bin, right-click on the deleted file and select "Delete" again. Restart your machine, this should fix the blue screen error.
Aspire zg5
aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
1helpful
My acer aspire 4741G , doesn't start up, it always goes to start-up repair, but it takes long for that process, then when it finaly finishes it still goes back to start-up repair, it it still...
Older Acer laptops use alt-F10. Newer Acer laptops use F11 to reset to factory operating system by hidden partition faster than restore cd..
System won't start and don't have recovery disc
Hi
you could try this
press the power on key
then straight away tap the alt tab bottom left along with the F10 tab top right
so its
power on
Alt+F10
this will hopefully take you into the factory recovery options
and choose what you want to do
then follow on screen instructions
hope this has helped you
please let us know if it did or didnt
so we may be able to help others
many thanks
How do reset my acer labtop to factory setting like restarting the whole thing erasing all data
I dont know if this will work your notebook it work for acer 5515 so try it.
On your Logo Boot ( this is when the acer name shows in your monitor) press "ctrl + f10" or if it doesnt work try "alt + f10"
this must load the recovery system page. Now in the recovery system page
Click on " Restore System to factory Default."
Then click "Next", "Next" then "Ok"
Just wait for the process to finish and when your asked for settings. just choose your own settings.
Now after recovering to factory default. i suggest not to do anything until your pc has completed installing your drivers and various programs.
If you see a "Acer" install toolbar at the bottom of your screen, your pc should restart after atleast 2 seconds.
Now after reboot your pc should now be ready.
Goodluck. Hope i help, please rate my solution , Thanks.
I have an acer aspire that i just got yesterday. i tryed to start it up last night and it started up. than i went to installed my internet stick on it the installion worked and than it went to a blue...
Hi.
Because the laptop is brand new there is nothing else we can tell that you haven't already done.
The only other thing that I can suggest is safe mode. If you can see the Acer logo or post information when you first turn the laptop on then repeatedly press the F8 key to get to the advanced boot options menu and then choose safe mode from the top of the list. Wait until the computer has booted and then click on the Start Menu > Control Panel > Uninstall a Program. Look in the list of installed programs for the internet dongle software and try to uninstall it.
If you can't see the program then I suggest that you use the recovery option to set it back to factory defaults.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
Choose option 1 and follow the instructions. If you have set up a password for Acer eRecovery then have it handy to enter it.
If after all this you are still getting the same symptoms then I suggest that you take advantage of the warranty and take/send the the laptop back as being defective.
Good luck!!
1helpful
How do i reboot my acer laptop 5310
Most Acer systems can be restored to factory settings using the following steps:
Turn on the system
When you see the Acer logo, press Alt + F10
(Press and hold Alt key, press F10)
Thanks
7helpful
3answers
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
1helpful
Installing XP
Acer computers come with a factory restore partition installed from the factory. The following instructions are direct from Acer's support website:
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
    4. Exit
  1. Enter the password created when eRecovery was first started.
  2. Read the on-screen warning and choose Yes.
  3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Acer reinstall issue
Run the same procedure again and choose factory settings. It wd do so , unless the recovery partition got corrupted.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
