How can activate my blackberry D1 china phone,mms, gprs and internet.
To Activate the MMS/GPRS you should call your service provider & tell them you Mobile Model & ask them for the GPRS Settings for your Mobile Model. They will provide you those settings for your mobile.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up & Testimonials //
SOURCE: problem with receiving pics via mms on cect i9 phone
You will need to configure your i9 for Cingular manually. You can find a manual with the GPRS and MMS settings at http://chinamanuals.com
SOURCE: I dont have the t-mo mms setting under data account
Rename one of the settings fet, etc
apn is - wap.voicestream.com
SOURCE: I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
