Onkyo TX-SR304 Receiver Logo
Posted on Aug 27, 2008
What remote control code does the Onkyo TX-SR304 use?
I want to program ComCast's 3 in 1 universal remote to control my Onkyo TX-SR304 receiver in the "AUX" position. ComCast's instructions have me use codes 30135 or 30842. The 1st one will turn the unit on...the second code will turn the unit off, neither will control volume. There must be a code that's out there that will allow ComCast's universal remote to completely control a SR304.
  • 4 more comments
  • Anonymous Feb 18, 2009
    Same exact problem.
  • Anonymous May 01, 2009
    The codes advised by Comcast fail to control the Onkyo Amp TX-SR304: code 30135 will switch it on, but will not switch it off, same, as far as I can tell with code 30482
  • Anonymous May 02, 2009
    Same problem, except code 30135 turns the SR304 on AND controls the volume, while code 30842 only turns it off. Called Comcast: they said that Onkyo corp gives them the codes to use. Called Onkyo: they said they only have codes for their own remotes, and the codes Comcast uses were from them. Unlikely, because of the hundreds of codes needed for all sorts of devices. Maybe Comcast gets an IR pulse code sequence from the mfgrs, and figures out the codes for their remotes from that.
  • Anonymous Jun 21, 2013
    onkyo tx-904 volume knob runaway
  • Bob Paszko
    Bob Paszko Dec 21, 2013
    What about an Onkyo TX-SR500 Audio Receiver? I tried the suggested solution to no avail.
  • Brian Plunkett
    Brian Plunkett Apr 05, 2018
    31805, supplied by xfinity site, works for me.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3910
Points
5
1) Tap AUX
2) Press & Hold Setup (1 then 2 blinks)
3) Enter 30842 or 0842 (The remote should blink twice)
4) Press & Hold Setup (1 then 2 blinks)
5) Enter 994 (2 blinks)
6) Tap Setup (1 blink)
7) Enter "00051" (1 blink per number)
8) Tap Power (not All On, just "power") (The remote should blink twice)
9) Tap AUX
10) Press & Hold Setup (1 then 2 blinks)
11) Enter 30135 or 0135
  • 1 more comment
  • Anonymous Nov 25, 2012
    OMG, this works!! After hours digging online for a solution, this is it! Thank you!
  • Anonymous Jan 05, 2013
    Thank you thank you THANK YOU. Wizard.
  • Bob Paszko
    Does the Onkyo TX-SR500 Audio Receiver use the same process?
Anonymous
Level 1:
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3910
Points
From: http://www.comcast.com/remotes/universal.html - only worked for me when I had AUX setup with 30135
Unlocking Volume Control For A Single Device (Individual Volume Unlock):
  1. Press a desired mode key where you want volume to be unlocked (e.g., AUX) and controlled within its own mode.
  2. Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
  3. Enter 9- 9- 3 and then press VOL- once. The mode key will blink four times confirming unlock.
    If desired, repeat steps I to 3 (of this section) for each device that you want volume to be unlocked.
Now, after you select a device that has volume unlocked (e.g., AUX), pressing VOL , VOL-, or MUTE will control the device's volume only in its own mode.
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work. Is...
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
tip
Download Onkyo TX-SR304 Manual
Download Onkyo TX-SR304 Receiver Users Manual
Have you misplaced your Pioneer Download Onkyo TX-SR304 Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Download Onkyo TX-SR304 Receiver Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
2helpful
2answers
How to program remote control?
Your Onkyo TX-SR304 receivers remote (RC-645S) is not capable of controlling devices by other manufacturers. It controls only Onkyo devices.
Other Onkyo remotes do have universal remote functionality and you can download Onkyo remote codes here.
I hope that helps.
________________________________________
Download Onkyo TX-SR304 users manual here.
I need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
1helpful
Dsp display on the 5.1 Onkyo receiver
Do you want to turn off the whole display?
There is a 3-way Dimmer on the front panel and the remote controller. The manual doesn't say if it will turn completely OFF.
Need codes for universal remote
Not sure if this helps, but I just called Onkyo with a request for codes for the SR304. They said the only codes they have are for THEIR remote. Maybe they will work with yours. Here they are:
0276 0476 0810 1187 1376.
I tried these in the Comcast remote (adding a 3 in front of the numbers) but that didn't work. Still trying to get my Comcast remote to program the Onkyo SR304 adequately, since their published codes only partially work.
Cant find universal remote code for the onkyo tx-sr605
Your onkyo receiver and remote controller only decodes 4 digit codes so what you have to do is to call the manufacturer of the remote controller it self and ask for the hexa decimal codes for their remote. They should provide it to you coz they're the ones responsible on doing that.
1helpful
Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
2helpful
2answers
Code for the onkyo tx-sr605
Try 1789. I just set it up it seems to work.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
