1991 Honda Accord Logo
Posted on Jul 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 1991 honda accord lx started making a loud clicking noise when i would turn the while driving, it started on one side and now both sides and really loud. What would cause that?
Anonymous
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Jul 17, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
21686
Points
172
This is caused by a worn or damaged outboard CV joint which will need to be replaced. Hope that helps..
Where is the fuel relay on a 1991 honda accord lx
Left side of dash near steering column. gray box.
3answers
When turning corners while driving my 91' honda accord lx, it started making a loud clicking noise, what could cause this?
Your outer CV joint is blown. You need to replace this soon - if the joint fails, the car will not move.
I have a 2001 Honda Accord Lx. I am having
This is something you have to remove the door panel to before you can say what it is. But I don't advise a DIYer doing it because its a little tricky. I recommend taking it to a body shop . They do this stuff in their sleep let them deal with it. If you try it and mess up then you have no door lock. This is not a big repair.
1helpful
Where is the fuel pump relay on 1991 Honda Accord LX
Above drivers side kick panes under dash on outboard side wall.
11helpful
2answers
Diagram of the 1991 honda accord firing order
  • Here is the diagram you requested. Cylinder 1 is on the right side.
Hope this helps.
1994 Honda Accord Rear Disc Brakes
you get all the lug nuts tight, the weight of the car on a loose lug can make that noise from the wheel, jack the car up and manually spin the tire, if you can give a more indepth description ill try to help, i have OnDemand5 if you have any other questions
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
