Eljer 124-0750 White SOFT-CLOSE TOILET SEAT 124-0750 Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nylon bolts on Eljer soft close seat that hold seat to toilet are stripped. Where can I get parts?
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on Jul 16, 2011
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
766243
Points
4966
Most hardware stores would have these nylon bolts -- also, Home Depot and the like.
Charlie
2answers
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 • Home
1helpful
Need eljer toilet seat savannah part no.124-1900-00
Google search: eljer toilet seat savannah
Top result shows following product:
http://www.lockeplumbing.com/detail.asp?c=Toilet%20Seats&s=Odd%20Eljer&s2=&sku=ELJ-124-1900-00&r1=WHE-USS25C&r2=GRU-595916&r3=FEI-NL9-LED
Eljer pdf shows same toilet seat
http://dallas.eljer.com/Products/Toilet/CatalogPage/0911905.pdf
Eljer customer service:
800-442-1902
Monday through Saturday
8:00 A.M. to 6:00 P.M. EST
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
2answers
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
28helpful
4answers
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Describe your Eljer &
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
Top Eljer Home Experts
john h
Gene Lawson
Sean Wright
Sean Wright
Are you an Eljer Home Expert? Answer questions, earn points and help others
