Computers & Internet Logo
Vito Perfetti Posted on Apr 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a pcchips p21g v1 motherboard, but it wont display anything when i power on the machine. A freind gave me the machine, it was a custom build with a 3.0 ghz p4 (Hyperthreaded with 2 threads), 2 gigs of pc 3200 400mhz ram, and 400 watt psu. (id rather not list the perifferals its too much information, i just wish to find an answer to my problem.) At first it worked fine, then it started to randomly freeze, then it crashed more and more often, then it wouldnt boot past bios, and now this. any ideas? Im a tech specialist, but im just dumbfounded by this problem.
  • Vito Perfetti Jul 16, 2011
    Also, the normal boot beep doessnt happen
solver2010
Level 3:
  • Master 923 Answers
  • Posted on Apr 26, 2017
solver2010
Master
Level 3:
Answers
923
Questions
0
Helped
192852
Points
2907
Is that one of the PCChips boards that has a jumper to enable/disable writing to the BIOS (Basic Input Output System? If it has a hard drive in it, disconnect or remove the hard drive, and then reset the BIOS, by removing the BIOS battery for 5 minutes, then put the (good?) battery back in, and boot it up without any hard drive. I have seen such behavior before, due to malware such as TDL4, and also "BadBios!" Those malware systems can OVERWRITE any unprotected BIOS with modified code!
5 Related Answers
Anonymous
  • Posted on Oct 19, 2008
SOURCE: 5 second beep/alarm
Hi krusty_623.
If this is new RAM, you might want to try removing the battery from the motherboard, resetting the CMOS (clears out all the old hardware settings) and putting the battery back in so that the motherboard redetects the RAM as if the setup was brand new. I've had the same problem only once on a RAM upgrade and it baffled me. Once I reset the CMOS the motherboard accepted the new RAM without any problems. I don't know if this will work for you, but it's a simple thing to try.
Spacetime
Anonymous
  • 124 Answers
  • Posted on Dec 17, 2008
SOURCE: I cant find which typ of mainboard do I have to preform an update
There is a little program called CPUz.
Download it here:  http://www.cpuid.com/download/cpuz_149.zip
Extract the exe and ini files and run the exe.
When the program comes up, click the Mainboard tab and your manufacturer and model are right there.
Anonymous
  • Posted on Mar 24, 2009
SOURCE: sound card drivers on bord
look et...According to the numbers you provided you have Elitegroup Computer motherboard. So for any possible BIOS upgrade, drivers or any other technical support you will need to visit => www.ecsusa.com. or call them at 510-226-7333. Suc6 Theo.nl
nyilasrobert
Robert Nyilas
  • 627 Answers
  • Posted on Jul 17, 2009
SOURCE: Computer won't load past Boot and now doesn't display anything!
the memory stick going in one way into the module. If you can't close the clips try to rotate it 180 degrees.
when windows starts hit F8 key and select disable automatic start on system failure.
This will bring you a blue screen with the specified error
also you can boot from windows xp cd and at first screen select repair, this will put you in recovery console
in recovery console you can scan your hardrive for errors like this:
chkdsk c: /p /r
Anonymous
  • 54 Answers
  • Posted on Dec 17, 2009
SOURCE: XFX 8600 gt not displaying on bootup
can't say for sure but I would believe it would have to be with your power supply, you might not be getting enough power out to run the card. Try putting in a different power supply and see if that works.
1helpful
My system cannot detect the integrated sound card of my P21G motherboard
Try re-installing the audio driver. Here it is:
http://download.ecsusa.com/dlfilepcc/sound/RealTek_v16.zip
If this is a problem from doing a clean OS re-install the don't forget to install the chipset driver first. You can get it here:
http://download.ecsusa.com/dlfilepcc/usb/usb_VIA_v100.zip
PCCHIPS P21G (V3.1) Complete Drivers list:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=364&CategoryID=1&DetailName=Driver&MenuID=1&LanID=0
Also, Check to make sure the Bios has the integrated sound set to "ENABLED".
If you still can't get it to work. You might want to just pick up a dedicated PCI sound card for next to nothing on eBay.
Connect frontal panel pchips p21g
You can download the manual for your motherboard at the following link:
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=364&DetailName=Manual&DetailDesc=P21G%28V3.1%29&CategoryID=1&MenuID=73&LanID=2
In the manual, you will find the front panel connections for your motherboard.
3helpful
2answers
P21G (V3.1) motherboad freezes and wont start
ขอ driver motherboard p 21 g v3.1 หน่อยสิ
Top PC Chips Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
