Master
- Posted on Jul 16, 2011
Re: Can you run the machine without venting it outside,I...
If an A/C unit is not pumping to the outside the hot air it removes from the room it's in, it acts as a dehumidifier. Without venting, the heat is just put back into the room.
More info, let me know.
Charlie
The most common cause would be the lack of pressure in the system (low refrigerant). There is a pressure switch which prevents the compressor from running (clutch engaging) when the pressure in the system drops.
Charlie
