Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Let me know if that link worked.
Thanks for the help but the link asks for a user name and password that I don't have.
Does the oven work a little?
Intermitently. It either works correctly or will not respond the the controls at all.
I would check the sensor for continuity and 1100 ohms. If it is shorted or has corroded quick connect that could be the problem. It might be in the control but I doubt it because if it was the control it would not be intermittent but a corroded sensor could feed irrratic readings back to the oven control plus it is way cheaper part than the control itself.
Thanks, I'll give that a try.
I'm having the exact same problem. Were you able to resolve the issue?
