Sometimes when the small pipe from the motor fan gets plugged up the motor will overheat. For safety reasons, the motor shuts off. If you able to start up the vacuum later, and the suction is not great, then follow the owner's manual to unplug the hose. It is not difficult, but it does require disassembly of the sweeper part of the vacuum. Make sure that you unplug the machine before you try to make any repairs. I have had to do this myself on occasion when the vac seemed to lose suction power. Another problem might be that you vacuum bag might be too full.
Since you mentioned that the cord is fairly new, I will make the assumption that you replaced the cord. If that is the case, then make sure the cord is unplugged from the wall, and check the connections of the cord to the vacuum. One of the wires might not have been attached properly and worked it was loose. This can happen especially if you pull hard of the cord when vacuuming. Oreck's come with a fairly long cord, but you still have to plug into a socket when you run out of cord.
If either of those suggestions does not work, then I recommend a service call to a local repair center.
