Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ERROR CODE F05 KEEPS COMING UP after machine runs about 3 minutes then it drains
Karen Andersen
Level 2:
New Friend:
  • Expert 86 Answers
  • Posted on Jul 16, 2011
Karen Andersen
Expert
Level 2:
New Friend:
Answers
86
Questions
Helped
25748
Points
254
It is a computer board problem and they will fix it for free if you call the main company and complain. There was a recall on the board and they fixed my daughters machine for free.
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Hi - my washing machine keeps f05 coding & the green start light won't come on
Is the outlet pipe blocked. Check this as sometimes the water gets backed up and this is sensed and an error is displayed
Error code f05 hotpoint ultima
In your service manual it states F05 - Pressure switch jammed on full many times I find this is due to a blockage in the drain line and if you take and clean out the drain line it usually alleviates the problem most of the time due to this error. I also find that while doing this it is best to also check the drain line that comes off the water opump as well as the one that goes from the bottom of the tub to the pump as well. Also checking the pumps impellar that it does spin freely assures future useage without problems for a much longer time with your washer. If you have any further questions message them back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
3helpful
My hotpoint washing machine is showing error code F05
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved.
Hope this helps... Please post back for further assistance.
Daniel
Code f02 keeps coming up
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$#$
3helpful
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Dear Sir my washing machine which is one year old started for the last couple of weeks todo unnecessarily noises and also it doesn not drain the water, showing code F05. WHAT TO DO? thank you!
F05 on an Indesit washing machine means "Pressure switch jammed on trip"
As is often the case, knowing the error code is one thing, but findng the cause is another because error codes often have several possible causes. The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too. Finally, the Indesit washing machines PCB's can give erroneous errors where the fault turns out to be with the pcb itself. This makes things very difficult if you don't have access to replacement PCB's to try.
Basically, I would keep an eye on the washing machine and try it again. If it reoccurrs then clearly it needs sorting, but if it doesn't it might have just been one of those things.
2answers
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
24helpful
2answers
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
2helpful
2answers
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
