Re: I am trying to unlock my phone & i punched in 1 9 6 3...
You may not unlock your properly , so it might shows the error message, In order to unlock your mobile successfully prefer best unlocking specialist, get the unlock code here unlocking4free using unlock code specified in it proceed unlocking your mobile & gain solution ..hope it will be very helpful for you...
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2. Enter *#865625# then the 16 digit unlock code
3. Device should say: Network Lock Deactivated
4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card
Power on the handset - phone will display "phone restricted"
Select "Cancel" - phone will display "phone restriction code"
Enter the SIM Unlock code.
Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card
2) Type *#865625#UNLOCK CODE
3) Press OK
4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone;
2) The phone display: Invalid Smart Chip
3) Power on handset
4) Select "Cancel" - phone displays "phone restriction code"
5) Enter the unlock code (8 digit code*)
6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card"
2 - Power on the handset - Phone will display "Invalid SmartChip"
3 - Phone will display "Invalid SmartChip"
4 - Enter 159753#*#
5 - Enter the 8 digit SIM Unlock code
6 - Select "OK"
7 - The handset is now successfully unlocked
Model : LG CU500
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
4 - Enter the 8 digit SIM Unlock code
5 - Select "OK"
6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card"
2-Power on the handset - Phone will display "Invalid SmartChip".
3-Enter *#865625# then select option 1 and then again select 1
4-Enter the 16 digit SIM Unlock code
5-Device should say: Network Lock Deactivated
6-The handset is unlocked.
7-How to Enter Unlock Codes on CU575 (Trax)
How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#.
2-Handset shows saved, then return to startup screen
3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4-Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2-Select 'Sim Unlock' menu #
3-Enter NCK code then validate
4-Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*#
2-Shows test menu
3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4-Handset shows 'Enter NCK'
5-Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2-Enter the code
3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
If your cell phone is not listed, please follow instructions for LG C2000 above
If
If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I'm using ATT as an example.
Phones are naturally unlocked, but a service provider might lock them
When originally manufactured, all GSM cell phones are unlocked. That is, they can be used with any SIM from any cellphone service provider - always assuming, of course, that the cellphone service provider has compatible GSM service on the same frequency bands that the phone can operate on.
Most cell phone service providers electronically 'lock' the phone so that it can only be used with their service. There are obvious reasons why they choose to do this - in particular, to force you to pay what are usually very high roaming charges when you take your phone out of their network and use it elsewhere in the world.
Fortunately, this locking is reversible. With some phones, it is possible to simply enter an unlocking password code into the phone and it is immediately then unlocked. Other phones need to be connected up to a special unlocking data terminal.
Your phone has to be unlocked by the carrier. LG, Motorola, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your carrier. For example, if you have AT&T to unlock your SIM card, you can obtain your phone's PUK code from AT&T by:
● logging in to your my wireless Account online ● using their Technical Support Chat ● calling Customer Care at 1-800-331-0500
To get your phone's PUK code online from ATT:
● Log in to your my wireless Account. ● Select My Services under My Account. ● From the My Services screen, select My Phone/Device. ● Select Unblock SIM Card. ● The Unblock SIM screen will display your PUK code.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong ATT PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
There are three other ways to unlock a phone:
● The carrier will unlock the phone for you at one of its retail outlets; ● You can do it yourself by clicking on this link Free Unlock Codes , ● Pay $3.89 at the following website: www.theunlockshack.com/.
I trust that this is helpful and solves your problem. All the best
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I'm useing ATT as an example.
Your phone has to be unlocked by the carrier. LG, Motorala, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
● logging in to your myWireless Account online ● using their Technical Support Chat ● calling Customer Care at 1-800-331-0500
● Log in to your myWireless Account. ● Select My Services under My Account. ● From the My Services screen, select My Phone/Device. ● Select Unblock SIM Card. ● The Unblock SIM screen will display your PUK code.
Warning: Entering 3 or more incorrect unlock codes may permanently lock your phone!
How To Unlock Nokia Phones
1. Power on your Nokia cell phone with an unaccepted SIM card in (or sometimes no SIM card at all works). 2. Type #PW+Unlock Code+1 (Where Unlock Code is your 8-digit Nokia unlock code) 3. Now verify your Nokia unlock code was typed correctly 4. Finish by typing # 5. If worked phone should say "SIM Restriction Off"
to unlock the phone use the att sim that came wid da phone
call up the customer care get the unlock code for the phone
now dial *#865625#(You punch this string in with your dial-pad - note that you only have access to the dial-pad when you have your AT&T SIM still in the phone) Then you'll be prompted for the unlock code you obtained from the carrrier, you have to punch that in and confirm, so a total of 2 times that you have to enter it.
When you try to enter wrong password for first 5 times you will see ***** marks on Blackberry screen,and then when you enter the wrong password again however Blackberry will display the password which you are trying to enter to make sure that if you are typing correct letters, symbols, special charecters etc
If a password is incorrectly typed ten consecutive times, all of the information on the BlackBerry smartphone is automatically deleted. This is a security feature.
These nokia 6300 phones cannot be unlocked by a generic code - and currently there are limited numbers of suppliers with the up to date software to provide unlocking tokens. These require your specific imei to generate the unlock code. You are probably best paying for someone to provide you (like a cell phone shop) to give you a valid token to key into your phone. Otherwise you will end up punching in incorrect codes into your phone and end up locking yourself out.
