Broderbund American Greeting CreataCard Select 7 for PC Logo
Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I had Creatacard for over 5 years & enjoyed it. Last week I changed to another computer . The technition didn't copy it to my new computer. Can you PLEASE tell how to retrieve the Program? Thanks you . Don Warren
Anonymous
Level 3:
Genius:
  • Master 1,098 Answers
  • Posted on Jul 16, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1098
Questions
Helped
177685
Points
3238
Hi there.
If you still have the cd installer, you can use this to install the program into the new computer otherwise, you really need to buy a new copy or get a similar freeware.
Please let me know if you need further assistance.
Thank you!
Micrografx creatacard 3 gold - repeat only micrografx, not american greetings
Micrografx Creatacard Gold 3 was created back in the Windows 98 days and most likely the installer is a 16-bit installer. Windows XP worked OK with 16-bit installers, but Vista, Windows 7 and Windows 8, 8.1 will not work. There is a work-around I found ( I actually found this fix for installing Photoshop 7 under Windows 7) and it works! I was able to install Photoshop 7.0.1 under Windows 7 Pro x64 edition and it works great!
Perform a search for Install-Photoshop-6-or-7-on-Windows-7 or go to this website http://www.wikihow.com/Install-Photoshop-6-or-7-on-Windows-7. Under this website, Look at Method 3 of 3 .
Stuff you will need:
1. A working Windows XP -SP3 system where you can install the Free Scalable Smart Package. You may be asking why? You will need to install the Micrografx Creatacard Gold 3 on this system with the "Discovery Program" running so it can create a new 32-bit installer
2. A CD-RW or a Memory Stick where you can copy the new .MSI file created and run it from Windows 7 x86 or x64 bit system.
3. Download the Free Scalable SmartPackager program. This used to be called WinInstall LE but they have since changed the name. You can find the program here http://www.scalable.com/smart-packager-ce-msi-package/. This is Free, but you still need to register to get the software. The latest version as of last week is v2.0.2.
4. Printed out instructions from the website so you can follow along. Once you perform this, you may end up trying this for other "older" software as well.
Basic Overview:
1. Under your Windows XP - SP3 system, install the Packaging software called Scalable SmartPackager v2.0.2
2. Once you have installed the SmartPackage program, it is a good idea to Reboot your system so all files get updated properly.
3. Start the icon called Smart Packager.
4. Under Smart Package, make sure you are under the Welcome screen and click on the Discover a new Package under Common Tasks.
5. When the Blue Discovery screen pops up, click on the Next button
6. Under the New Package Information screen, type out Creatacard Gold3 or something that you like
7. Under the Output Folder, Click the Browse button and select a folder or location where you want the new Creatacard Gold3.msi to be saved. Make sure you click on the Show advanced Options box below and Then Click Next
8. On this screen, you will now need to Click on the Start Discovery. This is what the SmartInstaller program will use to see where all the files are being installed to, etc when you run the Creatacard Gold 3 installer.
9. Insert the Micrografx Creatacard Gold 3 CD in the drive and install the program like you normally would. Please remember to install any of the Extra Free fonts as well during this time since this will be the only time you will have to create a new 32-bit installer (unless you run this process again)
10. After the Creatacard Gold 3 program has installed, verify it is working by Running the program and testing out various things within the program. (This is while the Discovery is still running in the background)
11. Once you have verified the Creatacard Gold 3 program is running properly (under the Windows XP system) then go back to the Discovery window and click on the Red Stop Discovery button and then click on the Next Button.
12. Make sure the Add new package to Smart Packager is checked and then click on the Finish button. This will now save the new "updated installer" MSI file over to the folder location you specified under option 7 above.
13. Copy this new *.MSI file you just created and either burn it to a CD-RW or copy to a Flash drive and take this file over to your Windows 7 system.
Please note, these instructions are an overview and may not contain the entire correct order. The last time I performed this was back in January 2014 when I first discovered the article about using Scalable Smart Packager to re-create an installer file into a true 32-bit installer.
For me so far, the installer has worked with Photoshop 7 and several Photshop plugins like KPT5, KPT7, etc.
I make no guarantees that this will work in your situation but it could not Hurt.
Plus, should you have problems removing this program I would recommend you try this Free program called Revo Uninstaller v1.95. This is Free for Home/Personal use only.
Hopefully you can use the above instructions I provided and get this great program to work under Windows 7.
Please let us know if this process worked for you or not.
FMNOT32
Copying the files will not necessarily work, certain registry settings etc will not be established. you may try to install the program (CreataCard Gold 3) using compatibility mode and check if it can be installed. Access the link below and follow the steps to manually change the compatibility settings and install the program in compatibility mode and check if it helps. http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the above steps do not work I would suggest you to contact the program manufacturer to verify if they have any updates of fixes to install this application on Windows 7.
How to back up forget me not. I tried to move it from one computer to another saving it on a flash drive didn't work.
I would buy another hard drive and mirror the hard drives. Then transfer the new hard drive to your computer. Mirroring will copy everything to the new drive
I have the very old version of American Greetings @CreataCard Gold v2' which I love. I bought the extra cards online which run from the CD by using an unlocking code. Unfortunately, I have had to...
On your old PC that has the registered Variety Packs, under the C:\Windows folder you should be able to find the vp.cc1 file. Copy this over to your new PC's C:\Windows folder and copy there. It is a good idea to backup this vp.cc1 file since this little file tells the CreataCard program what variety packs you paid for!
You should be now be able to access the Variety Pack with the Variety Pack maintenance kit that is included with the program. That way you can install the addons directly to the hard-drive instead of running it off of CD.
2answers
I have changed my computer to Windows 7 Home premium with 64 bit operating system. I have creatacard 3 and have tried installing it on my system. however it is not compatible with this system , how can i...
Start the "Windows Compatibility Wizard", and tell it that you want to install a "Windows XP" program. Windows 7 will then read the CD, and install the program, and run it in "XP" mode.
Can I get a copy of the procedure to change the 02 sensor on a 2004 Lincoln Aviator?
You don't need a copy of anything
All O2 Sensors are in both ends of the
exhaust converters on lincolns
All you need is a 22mm or 7/8" wrench
You will be changing only the front (2) sensors,
the ones closest to the engine at 100,000 miles
or when they fail
Ideally the check light or wrench etc & codes
don't always mean to change something
Assuming you won't know or have what is necessary
to test them, just change the front 2
Get the OEM NGK or Bosch at NAPA
Once you pull the sensor ,you will see the brand on it
The new wires may be 5" longer,just coil & wire tie
I used an old scan tool with a scope on mine, as a VOM
Meter didn't give you switching time & the scope really
was a nice test. You will notice an instant pedal response
with new sensors,I did with the Lincoln LS
Check that the rear monitor O2 sensors are tight
They loosen from the heat or were never tight from
the assy line
Hi, I have a sony vaio laptop, model PCG_3E2L. It's start up windows was vista home premium. Last night i change my windows. Properly i have changed my windows. But my webcam & touch volume option...
Ur right about it! When changing ur OS, u have to get new drivers for ur mo board and utilities( Audio, video, Network Lan, USB, and upgraded Bios).
Better go to Sony Vaio and download the drivers for the new OS!
Hi, I'm having a problem with my new dryer. We got this dryer about a year ago and for some reason in the last couple months, almost every 2 weeks the fuze blows. The dryer turns on but it doesn't...
Makecertain that your wiring is not exposed to anything. Be sure to turn the power off to the dryerand check the outlet. Also check to seeif your dryer cord is connected to the dryer right. Usually the outer prongs on the dryer are thehot and in the inner one is the ground.
May 11, 2011 • Dryers
I had an application called "creatacard gold 3" on my old computer with xp. I have all my important information from past 10 years is on that application. the computer crashed and i needed to buy a new...
The CreateACard Gold 3 (CAC Gold 3) will never work with Windows 7 64bit unassumingly because the software producing company has not upgraded their software for even Vista 64bit.
I recommend you to switch to " Hallmark Card Studio Special Edition" it has all the features of CAC Gold 3. You will enjoy it as there should be no problem installing it with Windows 7 64bit.
Good Luck!
7helpful
5answers
Creatacard 3
i hate Vista as well. i am trying to find a solution. my whole life over the past couple of years is wrapped up in the eventminder and fmnot32 files but after installing Creatacard on my machine with Vista, it will not recognize the files.
i open my address book, it's empty. i open my calendar it too is empty. how can i get this program to recognize the files i copied from the old machine? PLEASE HELP! i've tried everything including dragging them both over at the same time (file plus .BAK). i don't know what else to do.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
