Exercise & Fitness Logo
Posted on Mar 06, 2017
Hi, there seems to be some sort of electrical or software problem with my treadmill (york monza elite plus.) I only bought it yesterday (new) and it has run for a total time of under an hour. I noticed on my first use (at about 50 minutes) that the console screen 'blacked out', yet the treadmill continued to function. Going to use the machine again later, the buttons on the console would not respond but when I switched the machine off and then on at the back, the startup screen would automatically be displayed (without pushing any of the console buttons.) Occasionally, startup will get so far as to allow me to select a couple of functions but then cuts out again, making the treadmill unusable. Initially, I used a powerboard to connect the lead to the wall. I have since moved the treadmill so that I can plug it directly into the wall. I have since tried 'resetting' (including unplugging the power cord at both ends) but still only get a startup screen with buttons that don't respond. Any suggestions? Thanks
5 Related Answers
Anonymous
  • Posted on Feb 12, 2007
SOURCE: Display dies, although phone still functional
My razr V3 dropped from an astonishing 40cm to the floor, after that both screens stopped working. I opened the screen by removing the four tiny screws in each corner (t5 screwdriver which I didn't have but the smallest of my miniature screwdriver set just fitted), and popping it up carefully. There a two flatcables, one with a silvery color and a connector with a black piece of foam on it. I think it's the screen signal carrying cable. I removed it and put it back in place, pushing it firmly. After that the screens worked again. 10 minutes of work and a great deal of satisfaction. Further, the phone stinks. regards, El Rudo
Anonymous
  • 4402 Answers
  • Posted on Dec 15, 2007
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
A
Anonymous
  • Posted on May 23, 2008
SOURCE: Bernina Activa 131: buttonhole problem
There are TWO buttons on the machine that have the little u-turn on them. Look for the other one. That is the one that makes the second half of the buttonhole. Look in the owner's manual, it may tell you where it is on your machine. I spent a long time swearing at my machine before I figured out that the reverse is not the only button with the u-turn arrow. The manual is not clear on this. Why they use the same symbol twice is beyond me. Mine is on the front of the machine, down by the needle. Hope this helps.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Anonymous
  • 12 Answers
  • Posted on Mar 13, 2009
SOURCE: york treadmill
Depending on where you let the smoke out, but I would say yes. Remove the covers, I would look at the lower board first see the blackened areas. But the important question is why did it blow in the first place?
Gerritt
Serving the Twin Cities
Cardiozone Elite Plus HR T treadmill and am getting an error E11
Hello again
Having typed everything below the dotted lines for the last 30 minutes, I found this. It has a magnetic speed sensor on the pulley
https://www.justanswer.com/fitness-equipment/2srkz-just-moved-cardiozone-elite-max-hr-treadmill.html
Here is the parts diagram and it shows no speed sensor and all parts are unavailable.
https://www.fitnessrepairparts.com/equipment/Select/7631/CardioZone/CZE-Elite-Plus-HRT
Parts Diagram closeup
https://www.fitnessrepairparts.com/equipment/7631/diagrams/7403
That is contradicted here, but my view is that they are guessing because the parts diagram shows no sensor and if it was there and a part of the management system and expected to fail, it would be. There is a picture of of two sensors from Amazon and eBay, one is a Hall Effect Sensor, and the other is a Magnetic sensor. If it has them, you wouldn't be able to miss them and they would be connected to Part 17 - Controller.
https://www.google.com/search?q=cardiozone+elite+plus+hr+t+treadmill+sensor+replacement
Generic Treadmill Sensors
Treadmill RPM Speed Sensor - Replacement for Pacemaster Bronze, Pro, Plus, Plus 2, Elite, & Select Treadmill
$21.14
Amazon CA
High Quality Treadmill Magnetic Sensor Speed Sensor For Running
$12.89
eBay
Free shipping
WHERE CAN I GET SAFETY KEY FOR YORK 2750 TREADMILL PLZ?
you can go www.fitnessrepairparts.com or www.treadmillpartszone.com
God bless you
How do you calibrate a york treadmill?
yes you must read the instruction manual for software calibration.
or open the hood motor, and read the instruction attached.
or you must call to York supply for customer service and ask them where is located in case that you will not find them.
God bless you
2answers
Cracked deck
I bought a second-hand York Inspiration, and it developed the same problem. Upon dismantling the treadmill, I discovered the deck was cracked in two areas. My solution was to put a section of chipboard over the crack on the underside, securing each section with 12 screws. I used 16mm board. I cannot remember the other dimensions of the board, but it needs to fit between the deck support rails lengthwise, and widthwise between the screw holes for the foot rails. It is best to tape the edges of the boards to ensure they don't shed any debris once fitted.
The Inspiration manual contains an exploded diagram to assist with dismantling the treadmill. If you do not have one, it is available as a PDF on the web.
It's fairly straightforward to dismantle the treadmill.
The only part of any difficulty is the foot rails; once the screws for the foot rails are removed they stay put, as they are stuck down with strong double sided tape. Ease them off gradually. Once you have removed them, mark the front of each with a bit of tape, as the screwholes are not symmetric.
Hi My name is Ray and i have maytag commercial electric dryer model LDE19CS but the problem is i need to increase the time cycle,from 48 to 60 minutes. How i do that. I need manual
You either change the timer motor or you change the
Timing cams. Contact Lobright manufacturing in Queens village new york 888 - 829 - 0009
I do not know if my friend Bob Pinkney is still there but ask for him and tell him JW said hi. Ask him to send you a catalog. In it you will find all sorts of laundry matt stuff plus those cams and motors.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2009 • Dryers
York treadmill
Gerritt
Top York Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
