Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Convert VHS to DVD with a DVD recorder
What you need
A DVD Recorder ->
A DVD recorder is a device that looks like a DVD player, but with a writing function that can write content from external source onto a DVD disc. If you have ever read any other VHS to DVD tutorial, it should not be strange to you. In this case, we write VHS cassette footage onto a DVD disc.
A VHS player and your VHS cassette ->
Find them in whatever corner you left them years ago, and dust off.
An RCA or S-Video cable ->
This is the cable that connects your DVD recorder and your VHS player. Also be sure that your DVD recorder and VHS player are compatible with this kind cable, which they usually do.
This article can show you how to do it wwith detailed steps :
VHS to DVD Tutorial: How Can You Convert VHS to DVD at Home
will work or not.
Thanks for the response guys!
It wasn't a copyrighted program, it was a home video.
I did finally find the directions further down in the manual online. It's not as easy to find what you're looking for when you don't have it in your lap.
They call it dubbing, & it was as easy as hitting one button & it worked great!
Error indication u99
After development of the DVD drive and the frame lying under this the cause is nearby a horizontally placed circuit board one Elko 630 uF lid which ones probably lifted presumably is.
